boost ranges from 21-24 psi randomly?
Old Aug 8, 2011 | 06:32 PM
AWD96's Avatar
Start with a boost leak test. If your tuned for a certain amount of airflow, then you never want to push the limits past that point. It may be fine now, until you get a warm day or vice versa and kaboom something.
Old Aug 8, 2011 | 09:45 PM
sparky's Avatar
Originally Posted by taylorgang
What I meant was that the way that the buschur manual boost controller works; it only allows boost to be changed if the vacuum hoses are unplugged.....
Uh, now I get it, duh! You have the BR inline MBC that is installed axially in the boost line. OK.
Old Aug 9, 2011 | 12:20 PM
taylorgang's Avatar
well I'm on a pretty safe tune I rarely get knock... even when the boost creeps up. I doubt it's a boost LEAK but I'll check it out...
Old Aug 9, 2011 | 03:59 PM
HMatt's Avatar
Where is the boost controller at in relation to the motor? Changes in temp will affect the sping inside the MBC making it softer as it gets warmer.
Old Aug 11, 2011 | 07:09 PM
taylorgang's Avatar
its by the intake filter
Old Aug 12, 2011 | 09:14 AM
taylorgang's Avatar
Odd.. when I turned the mbc counter-clockwise 4 quarter turns (supposedly 4 psi) it went down 8 psi... so I turned it back up 2 quarter turns and it went up 4 psi... each quarter turn is supposed to be 1 psi in the buschur unit. Anyways, adjusted the mbc back to 21 psi
boost crept to 24 psi in 6th gear going up a hill... all was in the same weather
Would switching to an ebc fix this problem? Like i said earlier, I don't knock...
but my upper intercooler pipe did blow off the other day
awfulll smell hahaha... about 5k rpm in 4th gear around 80-100 mph I was like "finally!"
T BOLT CLAMPS HERE I COME!
HornstarBU
Lancer Aftermarket Forced Induction Tech
Feb 28, 2011 06:06 PM
fxyxixe
Nov 4, 2010 09:33 PM
JimGVT
Evo X How Tos / Installations
Apr 27, 2010 11:57 PM
EGbeater
Jul 22, 2008 10:32 AM
David Buschur
909
Jun 22, 2008 06:20 AM
