Boost gauge jumping
Old Feb 28, 2011 | 10:08 AM
HornstarBU's Avatar
Boost gauge jumping
Has anyone had their boost gauge read too high randomly, or jump up to 7psi, drop to -14, then 2psi while just cruising along, no change in engine speed or load. Mines a gloshift, so I know it is probably poor quality, but I thought I'd ask if anyone has seen this sort of thing.
Could it actually be pressure spikes, or is it more than likely a flaky gauge. The first thing that tipped me off was i hit "peak" and the gauge read 17psi...and I know I haven't hit 17psi. The wastegate boost source line looks good, no noticable problems there. Thoughts on testing it? air compressor, and just fluctuate pressure between 0-25, see if it works well at random changes, or just hold it at 10 or something and see if it stays solid?
I was thinking about getting a MAP sensor and monitoring boost, maybe I'll just do that, and compare the results.
Old Feb 28, 2011 | 10:41 AM
RoadSpike's Avatar
Does the car feel any different a -14 to 2psi flutter should be fairly dramatic. When i had my fp Red without the ported cover the turbo would surge pretty badly doing a flutter from 0-14psi and that shook the car pretty good.
If your not feeling the pressure in terms of shuddering I'd say your gauge just isn't working right.
Old Feb 28, 2011 | 01:06 PM
steven121's Avatar
Are you sure its not your fuel pump making boost? It's not gauge but the sender unit probably lol
Old Feb 28, 2011 | 06:06 PM
Demon_ni2's Avatar
COULD be compressorsurge. but... ive never heard of anyone really having that with our cars before. could also be a bad boost gauge with a leak or something along those line.
Ferp
Jul 13, 2023 07:31 PM
MajesticOne
Nov 20, 2016 02:34 AM
jb0evo
19
Mar 22, 2016 10:01 AM
Oki Panoki
Jun 29, 2011 02:47 PM
jhall651
Jul 4, 2007 01:52 PM
