Evolution ix rebuild
Old Aug 8, 2011 | 10:38 PM
bml1024's Avatar
hi i am doing a rebuild very soon on my evolution ix, but i am wondering what stroker kit should i go with, i would like to go with a 2.3l or 2.6l,or any one in between. I am looking for hp anywhere from 800-1000 hp. I am also wondering, i been looking up about 6 bolt and 7 bolt engines, and heard that 7 bolts arent as strong. Will i have to replace my engine block or is the stock one good to use? i am also wondering what is the best brand for parts to get (ams, buschur, jun, etc.)? thank you
Old Aug 9, 2011 | 04:31 AM
Mad_SB's Avatar
wrong section, moved to evo 1-9 section.
Old Aug 9, 2011 | 06:43 AM
Mikey@Spec-Ops's Avatar
Hey man, did your stock motor blow or are you just building?
Personally, I would recommend doing a LR2.4 High Compression. It would be the exact setup that I am running in my personal car. It is by far the best feeling street/strip motor that I have ever felt.
The older 7 bolts were not as strong as the 6 bolts. However, the Evo 7bolt doesn't crank walk.
If you are interested in doing a motor build I can help you. We do motor builds and will walk you through the whole process to get you what you want.
Here is my current setup.
ER MIVEC 2.4L Long Rod 4G64
ER ported/decked MIVEC cylinder head (Thanks to Jeff Bush)
ER modified MIVEC Cam Gear 33*
AEM Exhaust Cam Gear
Power Enterprise 1.2mm Head Gasket
Kiggly Racing valve springs
Kiggly HLA Oil Pressure Regulator
Custom Wiseco HD 10:1 pistons (87mm / 1.13CH)
ACL Race Main Bearings
Balance Shaft Eliminator Kit
GSC 156mm I Beam rods
GSC custom cams (Thanks Greg)
Boomba 75mm Throttle Body
Magnus v5 cast intake manifold (ported)
FP Black (Thanks Robert)
w/ R/TErnie modified housing & compressor cover (ported)
FP 25psi Shortened Wastegate Actuator
AMS Race Oil Pan
R/TErnie Stock Exhaust Manifold (Modified/ported)
R/TErnie vband 3" 02 Housing w/ 2.25" dump
R/TErnie Modified vband downpipe
ER 4" Intake no MAF w/ K&N 9" Filter
Omnipower 4 bar MAP sensor
ETS 3.8" Garrett FMIC
ETS 3" Short Route UICP
ETS 3.5" Exhaust w/ Test Pipe
ETS LP2 LICP
FP RacePipe (j-pipe)
TurboSmart RacePort 50mm BOV
SpoolinUp COP Ignition (Thanks for the custom kit Matt)
4 Piece Torque Solutions Motor Mounts (Thanks for the hookup Jay)
Exedy Triple Plate w/ lightweight flywheel
Shep Built Tranny (IX 1st, VIII 3rd/4th, HKS 4.11 Gears)
AEM TruBoost EBC Gauge
AEM Wideband AFR Gauge
AEM Oil Pressure Gauge
FIC 2150cc Injectors
Aeromotive fuel rail w/ steel braided lines
Dual Bosch 044 Fuel pumps
Stock ECU Speed Density
Omni 4 Bar Map Sensor
v7 w/ dual map tps switching (93oct & E85)
Mikey
Old Aug 9, 2011 | 07:28 AM
Craig King's Avatar
Why do I get the feeling that the OP is the same person that created this thread:
https://www.evolutionm.net/forums/ev...my-engine.html
Mods, IP check?
Old Aug 9, 2011 | 02:49 PM
bml1024's Avatar
AMS Race Oil Pan
ETS LP2 LICP
Mikey
why do you suggest to not use the 2.6l stroker kit? im just curious. i would deff like to talk more to you about this. And i am just rebuilding my motor, i want to be up to 800-1000 hp, thats my goal.
Old Aug 9, 2011 | 02:53 PM
A 2.6L would have a horrible rod stroke ratio. You would have to sacrifice a lot of rpms. The LR2.4 is the best all around motor out there. Let me know a time frame on building a motor and I can put something together for you if you would like.
Mikey
Old Aug 9, 2011 | 11:10 PM
bml1024's Avatar
so a 2.4l would be the stroker kit to get? i was looking at one kit that had titanium rods. And i have all winter, and well anytime from now to next spring. my goal horsepower at the total end is 800-1000, but that will be slowly after the rebuild. i am just looking to do the engine rebuild right now.
mrboost05
Jan 15, 2013 07:27 PM
Jacks Transmissions
Jacks Transmissions
Jan 4, 2013 12:26 PM
WickedIXMR
Jan 13, 2012 10:17 AM
Tonba
27
Jun 12, 2009 07:39 AM
RapidSpark
Apr 2, 2009 08:44 PM
