misfire in high rpm shifts
Old Aug 9, 2011 | 03:35 AM
sokaroza's Avatar
having misfire issue in high rpm right after shifting. doesnt do it with straight pulls just after you shift then punch it. any advice as to why this is happening????
Old Aug 9, 2011 | 06:45 AM
Mikey@Spec-Ops's Avatar
Can you log the car?
Mikey
Old Aug 9, 2011 | 10:56 AM
awdordie's Avatar
Have you cchecked the plugs and the gap?
Old Aug 9, 2011 | 12:34 PM
sokaroza's Avatar
Yes checked the plugs and gap. Still having the issue.
Old Aug 9, 2011 | 12:36 PM
sokaroza's Avatar
Mikey
I have no clue how to do that.
Old Aug 9, 2011 | 12:40 PM
It is most likely a tune/overboost issue. Take it to a near by shop and let someone look at it.
Mikey
Old Aug 9, 2011 | 01:30 PM
black_beauty's Avatar
Had this problem before, if you checked your plugs, I would look at the wires as well...
Old Aug 9, 2011 | 09:21 PM
sokaroza's Avatar
Mikey
Were at 30 lbs on e85. I have a spoiling up cod don't know why this is happening. I'm using ngk br7es. Should I use different plugs??? Maybe a step colder plug??? Ngk br8es???
Old Aug 10, 2011 | 06:31 AM
br8es have always been good to me
Old Aug 10, 2011 | 06:33 AM
Noize's Avatar
EvoM Administrator
I had that years ago in my VIII with a hairline cracked piston. But it was easy to tell, as I had a wet spark plug (oil) in the effected cylinder.
Old Aug 10, 2011 | 03:44 PM
Isaurio's Avatar
Tune the ECU and take it from there. If you still having the missfire i will check for the piston. Some member cracked their piston due from to much timing advance "Stock piston".
dillons13
Sep 2, 2015 06:25 AM
TLeid91
Aug 21, 2014 10:45 AM
jameswwt
Oct 18, 2010 05:36 PM
mitsuevodriver
14
Mar 6, 2010 10:16 AM
ExViTermini
AEM EMS
11
Jan 3, 2008 09:42 AM
