TB seals and EGR Blockoff?
Old Aug 9, 2011 | 01:12 PM
black_beauty's Avatar
Im replacing the TB shaft seals and my Q is: it possible to do the EGR block off while the TB is off?, or does the Intake manifold HAVE to come off? Thanks
Old Aug 9, 2011 | 01:15 PM
B.J.@ToxicFab's Avatar
Intake manifold does not have to come off unless you want to drill, tap & plug the EGR port in the head...With the TB off the EGR block off plate is easy to install...
Old Aug 9, 2011 | 01:21 PM
Mikey@Spec-Ops's Avatar
Correct! BJ is all over it
Mikey
Old Aug 9, 2011 | 01:24 PM
If i dont take it off and drill, tap, etc could this pose a problem? I would like to knock out the seals and egr/charcoal etc in one go...
Old Aug 9, 2011 | 01:41 PM
No, no problem at all.
Mikey
Old Aug 9, 2011 | 01:57 PM
Such quality people and info on this forum, Thanks
Old Aug 9, 2011 | 02:01 PM
Yep, BJ and I are awesome
Mikey
Old Aug 9, 2011 | 03:40 PM
Mikey
Old Aug 9, 2011 | 03:45 PM
The ONLY thing I have heard people mention about not plugging the EGR port in the head is possibly melting the gasket if you are running one of those thermal spacer style gaskets. I did not plug my head & I have been running one of those thermal style spacer/gaskets for the past 8k+ miles with no issues...
Old Aug 15, 2011 | 07:34 PM
ok ive read the how to, but if i dont plug the IM can i still remove all the charcoal/evap and all the solenoids?
Old Aug 16, 2011 | 04:35 AM
bbyevo8u's Avatar
where do the egr hoses go after the block off plate is installed?
Old Aug 16, 2011 | 06:33 AM
removed and the nipples capped...
Old Aug 16, 2011 | 06:35 AM
Yes you can, I have everything removed on my car including the EGR hardline that runs from the front to the back of the car...
Old Aug 16, 2011 | 08:52 PM
BJ is that the fat one that runs in front of the drivers side that we popped off to get the lines/hoses off the intake manifold? I think in the how to the guy cut his... and what is the connector beside the EGR solenoid, its just an elec conn, there are no lines. It goes under the intake runners, im just curious as to what it is...
fostytou
359
Oct 23, 2025 09:54 AM
SilentCool
Lancer Troubleshooting
31
Mar 13, 2018 05:07 PM
black_beauty
Feb 2, 2014 10:32 AM
rich3389
Mar 26, 2013 09:41 AM
kaonashi
Jul 29, 2012 06:55 AM
