Spark Plug Electrodes Broke Off
Old Aug 18, 2011 | 09:08 AM
jameswwt's Avatar
Originally Posted by EvoVIIIFL
Sorry for my closed minded thinking.. forget sometimes this is an international board
15-50 huh?
I know FL and Malaysia are 2 diff places but we do tend to share the blazing heat temps.. I'm running 20-50.. I'm wondering if the diff is what is causing the bearings to crap out on you
+1 but our dealers here only carry 15-50 or 300V...
Old Aug 18, 2011 | 09:54 AM
05blue8's Avatar
I've never heard a rod bearing causing a "tick"...I've seen 3 evo's with rod bearing failure and all 3 knocked and I mean knocked LOUD, not a tick. That being said if it's from the bottom end I don't see what else it could be
My car also eats plugs at times. I'm running e-85 which is prone to not knocking except a random 1 count every now and then. My issue is that when the electrodes break they go somewhere. In one case mine went through the exhaust wheel and killed my turbo bearings *sigh*
Old Aug 18, 2011 | 12:32 PM
RSMike's Avatar
no car should be randomly "eating plugs"...
If it's doing that, something is wrong.
Back the timing off.
E85 still detonates, we have seen it on a race engine. And the crazy thing is that you can't hear it on the det cans.
James - I dont know sorry mate. But i wouldn't run anything apart from 300V 15W-50 now, after seeing what punishment it can withstand
Old Aug 18, 2011 | 12:38 PM
EvoVIIIFL's Avatar
THIS^^
Now as for me in regards to oil just so you know.. I run THIS:
Ran this since day one 0 problems/issues
and thats now well over 70k on a built motor seeing 30+psi daily driven
Old Aug 18, 2011 | 07:37 PM
jameswwt's Avatar
Thanks Mikey...
Old Aug 19, 2011 | 01:41 AM
mirkendargen's Avatar
25PSI on a stock turbo sounds kinda steep on 91, were you tuned in the winter?
Edit: Just noticed your location...winter isn't very cold there, heh.
Old Aug 22, 2011 | 09:43 AM
raph's Avatar
Changed the oil and filter this weekend and my drain plug collected a good amount of metal shavings. I didn't get a chance to cut open the oil filter though.
Old Aug 22, 2011 | 10:34 AM
jameswwt's Avatar
- My drain plug collected a good amount of metal shavings.
Me too!
Old Aug 22, 2011 | 12:06 PM
surferjeff's Avatar
Sounds like your are dropping fuel pressure or overheating the fuel. If down on power and using ethanol, it will still drive but you lose a lot of torque and power at high AFR. I would check your FPR line and other vacuum lines for leaks and check or replace your fuel pump or pumps.
Either that or you may just have a bad tune.
cerealkeller
Sep 7, 2016 04:50 AM
inshallah
Jul 5, 2016 07:52 AM
plan:b
Dec 25, 2015 09:07 AM
13-0
154
Aug 16, 2015 12:57 AM
deadbeatrec
Feb 16, 2008 05:48 AM
