AMS oil pan question
Old Aug 17, 2011 | 01:22 AM
Pirana's Avatar
Question AMS oil pan question
I've been contemplating getting an AMS oil pan for my car....2.3L, if not only for its looks but for the extra oil capacity. I dont do race courses or autocrosses, but do like the pan as an addition to my car. Now I understand that it comes with a griddle and scrapper, but my question is...can I just add the pan and not install the new griddle and scrapper? Since I would have to clear it and I'am no engine builder.
https://www.evolutionm.net/forums/ev...ay-pics-4.html
Old Aug 17, 2011 | 07:10 AM
RockmanX's Avatar
im positive kevin can/will do it for you
Old Aug 17, 2011 | 07:43 AM
Pirana's Avatar
I understand that, thats not the problem....I have my car in jackstands putting the tranny back on. So this would have been an easy swap of oil pans.
Old Aug 17, 2011 | 06:02 PM
opie's Avatar
Do it I love mine after I had a machine shop fix it. When I got it from Ams one corner was higher then the rest and Ams told me to put in on something flat and hammer it out straight but that did not work so i had the machine shop fix it. So before you install it make sure it is flat
Old Aug 17, 2011 | 06:18 PM
Pirana's Avatar
Did you use the supplied scrapper? Or just installed the pan?
Old Aug 18, 2011 | 05:00 PM
opie's Avatar
My motor is a 2.2 and I used all of it. Just one little place needed a little grid to make work on the scrapper
Old Aug 18, 2011 | 05:10 PM
Pirana's Avatar
Cool. Thanks for your input.
Old Aug 19, 2011 | 03:59 AM
justincase's Avatar
Does this pan require a relocation of the oil filter? Sorry for the question just heard as such off someone and couldnt find any ifo saying as such.
Old Aug 19, 2011 | 05:17 AM
opie's Avatar
no the oil filter does not get moved
Old Aug 19, 2011 | 05:26 AM
binky's Avatar
Make sure when you go to put it on to have PLENTY of RTV. It takes a lot to make this pan seal correctly.
Other than that it's a great pan, I love it. Also, FYI when you change your oil now, make sure you add 6 quarts (with a new filter), 4.5 with old filter (not sure why you would use an old filter though).
-Bink
Old Aug 27, 2011 | 05:35 PM
Pirana's Avatar
Well I ordered the pan and will be here on tuesday!!!
Old Sep 1, 2011 | 08:35 PM
Kidloco51's Avatar
I am in the market. Who did you order it from?
Thanks
Old Sep 1, 2011 | 10:27 PM
Pirana's Avatar
Best price was AMS. Though call them directly or PM Andrew here on EvoM.
Old Oct 21, 2013 | 11:26 AM
AnabolicEVO's Avatar
Is there still these fitment issues going on with these oil pans on stroker engines? I'm looking for some input before I purchase one. Thanks in advance
Old Oct 21, 2013 | 12:26 PM
binky's Avatar
I've had mine going on 2 years and it's been rock solid. No leaks.
-Bink
