Built Evo still running lean.
I made a thread earlier trying to figure out why my car was running lean all of a sudden. I ended up finding the problem which was a vacuum line that hooks to a solenoid that activates the second fuel pump on my double pumper had blown off. I fixed it and went out to log the car. It helped but its still not right. When the hose was blown off my a/f were around 14.2 at WOT. Now with the hose fixed they are at 13.0 which is better but needs to be around 11.8 like it used to be at WOT. I ran a tank of 93 octane through the car and waited till my gas light was on and drove a little more until I filled back up with e85. Could the little bit of 93 octane that was left in my tank be causing it to still run a little lean? Could I have damaged one of the fuel pumps while running it with the solenoid not being activated? Please help. I need some suggestions.
what is your idc like? Are you sure both pumps are coming on? I had my hobbs switch go once and was thinking it was the pump so I brought two new pumps and later found out it was the hobbs switch.
Good luck
Good luck
Sorry to sound like an idiot but what parameters do i set to log my idc on my AEM? And obviously something different is happening now that my vacuum line is hooked back up to my hobb switch bc my a/f went from 14.2 at wot to 13.0 after hooking it back up.
Would it be possible that I damaged the primary pump bc while the hobbs switch was disconnected the primary pump was trying to do the work of 2 pumps?
check vacuum lines on ur intake mani for loose connections make sure all secure, and no slits in the lines, other thing is check your intake pipe for any holes, also for any missing fittings. any thing pre turbo or post intake mani with vacuum lines, can cause it to run lean. Now did you do the basic like checking the vacuum lines behind throttle body by the egr area. one of those pop off it can cause the car to run lean.
check vacuum lines on ur intake mani for loose connections make sure all secure, and no slits in the lines, other thing is check your intake pipe for any holes, also for any missing fittings. any thing pre turbo or post intake mani with vacuum lines, can cause it to run lean. Now did you do the basic like checking the vacuum lines behind throttle body by the egr area. one of pthose pop off it can cause the car to run lean.
I think one of my fuel pumps is damaged from the hobbs switch being disconnected and the primary pump was getting over worked trying to do the job of two pumps. Like I said though is how do you know which fuel pump is the primary when you pull the cradle out of the tank?
Ted B
146
Aug 12, 2015 11:45 AM
TouringBubble
Jan 30, 2010 06:17 AM
