Running Lean
Old Aug 14, 2011 | 09:30 PM
AcePitcher11's Avatar
Running Lean
2005 Evo. Fully built yada yada yada. It is an AEM car.
I recently converted my car to run E85 and after about 2500 miles of driving the r is running lean at WOT. Cruising and idle a/f are perfect but at WOT my a/f is around 14.2 eek. It was around 11.8 at WOT but just recently started this lean crap. My fuel system is all adequate BR double pumper, ID2000s, BR fuel rail. I pulled my injectors off the other night and they had a little crud around them so I cleaned them out hoping that was the cause but the problem is still there. I am in the process of running the e85 out of my car and running 93 octane through it to try and clear things up. Any other reasons of why my car is going lean all of a sudden? Could there be a restriction somewhere else?
Old Aug 14, 2011 | 10:46 PM
06RedRalli's Avatar
Check the fpr hose on the intake manifold...might have come off...
Old Aug 15, 2011 | 12:14 AM
awdordie's Avatar
Havve you checked the wb sensor it itself could be going bad giving false readings.
Old Aug 15, 2011 | 03:11 PM
Any other ideas?
Old Aug 15, 2011 | 04:13 PM
awdordie's Avatar
One of the fuel pumps could have went bad?
Old Aug 15, 2011 | 04:27 PM
WRC-LVR's Avatar
bad fpr as well
Old Aug 15, 2011 | 05:53 PM
marrrk's Avatar
fuel filter?
Old Aug 15, 2011 | 05:58 PM
Spec-Ops1's Avatar
Second pump triggered by AEM or Hobbs switch? Check those out...
Old Aug 15, 2011 | 10:30 PM
Kawboyz11's Avatar
Check the fuel filter. E85 is known to clean out the fuel tank and lines which can clog the fuel filter rather quickly
Bmurray
59
Jan 24, 2017 08:19 PM
aquaMan219
Dec 18, 2016 05:28 PM
5LEEPERISAH23I
Sep 10, 2011 05:02 PM
5LEEPERISAH23I
Sep 6, 2011 05:28 PM
DarksideEng
Feb 26, 2006 11:47 AM
