big injectors without a new pump?
Old Aug 22, 2011 | 06:47 PM
killerpenguin21's Avatar
im kicking myself for even asking this, because i definitely know better and have more experience but...
i feel im out of injector on my car (consistent 99-102 idc's and cant get it any richer) with the stock turbo/ injectors/pump. im going to purchase some fic 1050's to leave enough headroom for the future (cams, o2 housing, e85 if i move etc).
right now i just need something to add half a point to my afr as im riding 11.8-11.9's which i dont like.
i guess overall im wondering what the limit of a ix pump is? and if it would cause any problems to run 1050's on a stock pump when im not pushing it?
i know i need a pump eventually, but due to my need for the car as a daily at the moment, i dont feel like having a fuel pump take a **** on me shortly after install since i had been planning to try out the dw/aeromotive stealth pumps which havent really proven themselves yet...
Old Aug 23, 2011 | 09:18 AM
i suppose the lack of response proves the stupidity of the question lol.
Old Aug 23, 2011 | 09:54 AM
Ev0ikon's Avatar
Just replace it with a Walbro.
Took me 2 hours to do it and I am not even that good with hand tools after some beer!
Old Aug 23, 2011 | 10:26 AM
i will not use a walbro. ive had them in 2 previous dailys, and the noise annoyed the living hell out of me.
Old Aug 23, 2011 | 10:54 AM
DeatschWerks's Avatar
Since you won't be pushing the pump too hard with your current build, dropping our DW301 in should be an easy task.
Our pump has been out for over 8 months now, and we already have thousands of pumps out in dealers and customers cars.
Old Aug 23, 2011 | 11:58 AM
211Ratsbud's Avatar
A pump may be worth a half point afr... Injectors will surely not have a problem, where is your peak idc ?
Old Aug 23, 2011 | 02:29 PM
It's above 6k of I recall, I'll check tonight. I've got requests down to the low 8's in my rom and I got a 3% bump in idc But no change in afr...yor not the first person totell me I should be able to go further on the stock injectors either...
Old Aug 23, 2011 | 04:45 PM
sparky's Avatar
How much boost are you running? As someone alluded to...with your very mild mods( stock turbo, pump gas tune, and stock cams) the stock injectors combined with stock the IX pump should be able to deliver all the fuel that you need.
Old Aug 23, 2011 | 05:18 PM
peak is 24psi, making a consistent 330/300 on vd, but my afr's are stuck at 11.9 on my wideband.
Old Aug 24, 2011 | 04:07 AM
PaEvo's Avatar
def need an upgraded fuel pump. go walboro 255 ltr/hr and dont look back. if u plan on goin big go with a double pumper = one walboro 255 for sending, and one for return. many reputible tuners offer a drop in double pumper w/ hardware for an affordable price
Old Aug 24, 2011 | 04:20 AM
sparky's Avatar
Originally Posted by PaEvo
def need an upgraded fuel pump. go walboro 255 ltr/hr and dont look back.....
The Walbro solution has already been suggested. However, the OP has stated in no uncertain terms that he cannot live with the noise of a Walbro pump on a daily basis.
Old Aug 24, 2011 | 04:39 AM
TxEvo8's Avatar
So you aren't getting enough fuel to your stock injectors and your solution is to get bigger injectors? Does that make sense? You need a fuel pump, and if you dont want another Walbro, then take your chances and get the DW or aeromotive. I would definitely put in the Wally, takes about 20 mins. Good luck with whatever route you choose.
Old Aug 24, 2011 | 04:58 AM
sparky's Avatar
def need an upgraded fuel pump..... if u plan on goin big go with a double pumper = one walboro 255 for sending, and one for return....
Don't assume that in an intank double pumper setup the secondary pump is dedicated to performing return duties. This would be wrong. Both pumps share the same function of supplying fuel to the rail. The outlet of both pumps is T-eed into a common feed line which supplies the fuel rail.
Old Aug 24, 2011 | 05:05 AM
wizzo 8's Avatar
If I were you I would get the dw pump. It should push more fuel through the stock injectors to hopefully get that half point. I just installed my dw and its a quiet pump. It will also be cheaper to get a pump instead of injectors. If you plan on running e85 in the future I would also go with at least some fic1450.
Old Aug 24, 2011 | 05:10 AM
sparky's Avatar
In the meantime, you could either add a KenneBell Boost a Pump, or hot-wire the stock pump to increase voltage.
