big injectors without a new pump?
Old Aug 24, 2011 | 05:15 AM
sparky's Avatar
Originally Posted by wizzo 8
.... If you plan on running e85 in the future I would also go with at least some fic1450.
These are the injectors of choice for a stock appearing turbo on E85! I wish I had purchased these puppies instead of my RC 1000 nozzles.
Old Aug 24, 2011 | 07:51 AM
killerpenguin21's Avatar
Originally Posted by TxEvo8
So you aren't getting enough fuel to your stock injectors and your solution is to get bigger injectors? Does that make sense? You need a fuel pump, and if you dont want another Walbro, then take your chances and get the DW or aeromotive. I would definitely put in the Wally, takes about 20 mins. Good luck with whatever route you choose.
your missing my somewhat skewed thought process.
stock injectors hit their absolute limit (go static?) somwhere in the 105-110 range in evoscan. that being said im pushing 103 from 6k up on stock injectors. ive always tried to keep my setups on every other car ive owned below 90 to be comfortable.
to me that doesnt mean im out of pump, it means im out of injectors. the thought was that putting in th ebigger injectors will give me a little safety pulling the idc's way down without requesting anything more from th epump for the time being. i know i need a pump, i just need to hold off on putting it in for now if possible.
as far as e85, its doubtful it will ever happen since i live in a state with zero pumps. it was just a thought in case i move at some point in the next two years. otherwise i just need enough fuel to support cams and the possibility of a stock block red/bbk setup.
Old Aug 28, 2011 | 02:07 PM
supersal's Avatar
If Aftermarket pumps are too noisey for you, consider:
A double pumper set-up which utilises two stock pumps
Old Aug 28, 2011 | 03:13 PM
211Ratsbud's Avatar
Orr hardwire stock pump to
Old Aug 28, 2011 | 03:49 PM
240Z TwinTurbo's Avatar
I ran the stock pump on my IX and reached a point where it dropped fuel pressure. I have DEFI gauges so I could play back my runs and noticed the fuel pressure dropped at ~23psi and high rpm. I then swapped to the Walbro and fuel pressure remains constant. With the Walbro I don't notice any excessive whine from the pump. I would not recommend to add injectors without also upgrading the pump. Depending on your hp goals you may want to look into the Walbro or the new Aeromotive, which seems to provide the most flow for a single in tank pump.
Old Aug 28, 2011 | 03:51 PM
You really need to monitor fuel pressure at full boost and high RPM to safely conclude it is not a pump issue.
Old Oct 6, 2011 | 10:08 PM
silverevo05's Avatar
so did you get an answer? bigger injectors without a fuel pump?
LSs1Power
54
May 16, 2017 01:06 AM
Ian0611
50
Jul 6, 2016 11:50 PM
awhit17
Sep 19, 2015 02:38 PM
Graphic
Feb 26, 2012 11:59 PM
l2r99gst
May 30, 2009 11:48 PM
