Question?
Old Jan 2, 2004 | 11:21 AM
EVO2003VIII's Avatar
Question?
Hi and happy 2004!
I have a question: I put a catalityc converter to my evo 8 and the service engine soon checks out. The code is for oxygen sensor. How can I take out the signal without taking out the catalityc converter?
What should I do?
Eddie
Old Jan 2, 2004 | 11:22 AM
SilverEvo8owner's Avatar
do you mean you put a highflow cat on?
Old Jan 2, 2004 | 11:25 AM
I only took out the catalytic. The sensor goes before the catalytic. But the catalytic converter comes with a hole to put the sensor there. I tried the 2 ways and stills checks the light.
Old Jan 2, 2004 | 11:48 AM
limey's Avatar
very confused try and explain properly...there are 2 o2 sensors on the evo....if you install a cat delete pipe you will get a CEL.....
Old Jan 2, 2004 | 12:35 PM
That's what I have, a cat delete pipe. The last sensor goes before the cat delete pipe. If I leave it like that the service engine soon light appears. The other way is to move the sensor to the new pipe that comes with a hole and also appears the light. What can I do to stay with the cat delete pipe with out the warning light??
Old Jan 2, 2004 | 12:59 PM
EvoJimbo's Avatar
Where did you get your Cat delete from? I'm running teh UR cat delete which doesnt trigger a CEL.
Old Jan 2, 2004 | 05:11 PM
I just buy it from the internet. The guys at mitsubishi said the the only way the light is going to stay off is by putting again the catalytic. So if there is something that I can do to the O2 ?
I really feel the car better with the cat delete pipe.
Old Jan 2, 2004 | 05:13 PM
imsonastie's Avatar
you speak backwards.. but anyway there isnt an 02 sensor right before the cat. it's right after. the other o2 sensor is right after the turbo housing isnt it?
Old Jan 2, 2004 | 05:20 PM
after the cat there is one and before there is the other one. Well, when I install the cat delete I left the sensor where it was. I don't mean the first one, I mean the one that reads before the cat. When I run the car for at least a day the light of service engine soon appears, I erase it taking the negative battery out and change the second o2 to the new cat delete that comes with a hole and again the light appears. Maybe the computer reads that there is a lot of bad mixture of gas and air and hit the light of service engine soon. So my question is what can I do to stay with my cat delete pipe>?
Old Jan 2, 2004 | 05:25 PM
imsonastie's Avatar
i have the cat delete pipe also and it seems to run fine. it is just anoying having that light on.. try takin out the cel fuse in the engine bay for about 15 sec. then put it back in. i think it is 4th from the bottem. but it isnt the one by tself on the top if you look on the diagram.
fugiwara
Dec 30, 2016 12:05 PM
stayinalive85
Lancer Engine Management / Tuning Forums
Aug 4, 2016 03:17 PM
EvolutionRacing
Apr 6, 2016 10:29 AM
MarioTME
Apr 27, 2009 12:18 PM
Shadymch
28
May 11, 2007 10:15 PM
