Taping????
Old Aug 29, 2011 | 12:08 AM
Robertv34's Avatar
Taping????
Ok well I bought an evo that needed some work.....long story short It sounds like something from the head it has a built motor and turns on first try. I really dont think its a bearing because you hear nothing from the bottom end you hear it up top now I am asking what do you think it could be from my experience I would say valve or lifter tick like the dsm had. But is this usual on an evo??? I know its hard to say without a vid but it just taps all through the rpms and Im definatly sure it aint a bearing.......
Old Aug 29, 2011 | 12:58 AM
MasterNater's Avatar
Yes, lifter tick is very common, just like the old DSMs. The 4G63 is a noisy motor in general.
Old Aug 29, 2011 | 11:35 AM
Robertv34's Avatar
So I pulled out my tapping lifters and did the bleed as told to and now they all fckn tap should I just replace all with new????
Old Aug 29, 2011 | 11:48 AM
dastallion951's Avatar
well if i remember correctly after you pull them and bleed the air out after reinstall, its recommended to rev and hold rpms about 3k for like 10-15 seconds, do that a few times, after a few times, the noise should go away unless theres another issue present, you sure you reinstalled the rocker arms right?
Old Aug 29, 2011 | 12:20 PM
Robertv34's Avatar
Is there a way to install the rocker arms wrong??? I thought they would just fall off If you did install them wrong...
Old Aug 29, 2011 | 12:28 PM
RoMeIX's Avatar
I think that they can only be installed one way. I have had lifter tick since I bought the car new, I just got used to hearing it over time.
Old Aug 29, 2011 | 12:33 PM
mdsevo06's Avatar
The JAM's do the same as well. I haven't heard anything on the GSC's, but it seems no matter how big the port, it will still tick over time.
Old Aug 29, 2011 | 01:31 PM
Robertv34's Avatar
ok so just pulled off the cams again and all the lifters i can push down with my thumb as if i just blead them..........all this happened after i blead the lifters put them back in started the car and ran for 5 min holding the throttle at 3k and droping back down to idle 10 times or more repeated this process............What can the problem be y arent they getting oil???????
Old Aug 29, 2011 | 06:43 PM
Robertv34's Avatar
update pulled them out blead them again and same sh**t what the heck can it be im so pissed off its loud as hell too I cant get used to this noise its horrible and sounds super loud!!!
Old Aug 30, 2011 | 11:34 AM
they all might be collapsing, best bet buy a new set or swap another set of known good oem lifters, when you bleed them how did you bleed them? when i bled mine i used a bit of good new oil in a plastic container took each old lifter, used a paper clip collapsed the pintle iirc inside of it did it a few times, got some gunky old oil out in another container, then pushed the new lifter in the new oil, and then set it aside in the order it was in the head, and kept goin to each till i was done. Then I reinstalled, now iirc theres a 2 part process to reinstallin them in the head, i forget off the top of my head the 2nd part but do a search on here for how to bleed and properly reinstall the lifters. good luck.
Old Aug 30, 2011 | 11:40 AM
GregGSC's Avatar
Cracked Guides can make a ticking noise. We had an engine we put together we chased our tail on that had guide issues and made a tapping sound. we changed lifters, cams, rollers, and injectors before we removed the head and checked the valves and guides.
checking for rod bearings is easy just pull the coil to each cylinder seperatly while the car idles if the tapping stops with the coil pulled than its a rod bearing
Old Aug 30, 2011 | 05:20 PM
Robertv34's Avatar
Ok guys thanks you both of youI will check to see if I did the proper re install and Greg What about a leak down test would that show me if the valve guids are good or not???
Old Aug 30, 2011 | 06:30 PM
sparky's Avatar
It might be a good idea to do both a compression test(pressure) and the leakdown test(leakage) to get a better picture of the health of your engine.
Old Aug 30, 2011 | 11:56 PM
mirkendargen's Avatar
My stock injectors are really loud, you might check that. I thought it was lifters for the longest time, but then happened to just feel one of the injectors and yup...that was it.
eddy5201314
Apr 3, 2014 03:25 AM
MitsuJDM
44
Dec 18, 2012 06:48 AM
him
Apr 27, 2012 09:40 AM
alenewit3928
Oct 29, 2011 06:46 PM
Frank120
Oct 19, 2010 04:08 PM
