ID2000's (high impedence) WITH resistor pack...runs great...?
Old Sep 3, 2011 | 12:08 AM
TurboTravis's Avatar
Guys,
Long story short-I'm running ID2000's and still have the factory resistor pack installed. Car runs/drives/idles great, zero complaints. My question for ID on Tuesday is am I hurting anything...but I can't see how. I can see how imposing too LOW of a resistance on the ECU could hurt it, but def not too high of a resistance. If you have an educated opinion, please post it!
Thanks
Travis
Old Sep 3, 2011 | 05:53 AM
Spec-Ops1's Avatar
You arent inducing a low resistance to the ecu, you are limiting the ammount of voltage to each injector... why would you not just bypass the resistor pack, takes all of 30 minutes...
Old Sep 3, 2011 | 08:39 AM
I have zero issues with doing it, I just didn't know it had to be done at the time. I'm just wondering if it will alter the tune.
Old Sep 3, 2011 | 09:04 AM
mrboost05's Avatar
freddie i just emailed you btw and to the op here is a post from the man himself i used this for my fic2150
https://www.evolutionm.net/forums/ev...istor-box.html
Old Sep 3, 2011 | 09:31 AM
omarnasser's Avatar
hey , could i just use the spoolin up bypass instead???
Old Sep 3, 2011 | 11:57 AM
Spec-Ops1's Avatar
Yes you can use spoolinup bypass as well
Old Sep 3, 2011 | 11:58 AM
Spec-Ops1's Avatar
Yes it will alter the tune... I would recommend doing the bypass... but your car do as you please...
Old Sep 3, 2011 | 01:23 PM
dsmfan95's Avatar
Thanks
Travis
As stated earlier, you would be limiting the voltage at the injectors. Not having enough voltage could cause them not to function properly, especially at full load.
PAdutch
Mar 21, 2017 01:01 PM
Brsox10288
Oct 19, 2011 09:18 AM
Outlanded
Jun 5, 2011 10:56 AM
Street gear
Feb 28, 2010 04:33 AM
