MBC is maxxed out and Need moreee boost
Old Sep 12, 2011 | 04:18 PM
My03evo's Avatar
Arrow MBC is maxxed out and Need moreee boost
Sorry for the newb question but just need some reassurance, im at the point where my forge mbc is bottomed out and wont go higher than like 30psi....Most of the parts are in my sig, I believe my black has the normal 17ish psi actuator (Vs the other 25psi one). Do I need to upgrade to the higher psi actuator to raise the boost or am I missing something simple?
Old Sep 12, 2011 | 04:25 PM
RSMike's Avatar
more preload so the flapper doesn't open as much?
Old Sep 12, 2011 | 04:28 PM
inco9nito99's Avatar
Get a FP25psi wastegate actuator, (at which point the LEAST amount of boost when properly adjusted should be 25psi). Lower your MBC to the softest setting and then SLOWLY tighten it while carefully monitoring boost; you should have no problems at that point.
Also make sure you have a good spring in the MBC, a soft spring is likely the cause at the current moment. If not, time to upgrade the wastegate .
edit: Dave pointed out something I forgot to mention assuming you already knew to make sure you have no boost leaks or other mechanical issues that would inhibit proper building of boost.
Old Sep 12, 2011 | 04:54 PM
wizzo 8's Avatar
Yea you can get a 25psi actuator or try and tighten up your wastegate linkage. I would try to tighten the linkage before stepping up to a 25psi actuator. Its free to tighten up the linkage if you can do it yourself.
Old Sep 12, 2011 | 04:56 PM
David Buschur's Avatar
None of the above.
If you don't have any boost leaks and a BOV that actually holds boost then the problem is the actual boost controller. Replace it with a real manual controller and you will have all the boost you will ever need. I do not recommend the HD actuator actually, you don't need it
Old Sep 12, 2011 | 06:02 PM
Boosted Tuning's Avatar
The OP defiantly doenst need to BUY ANYTHING Dave.
OP, All you need is the "hard" spring. Call or Email FORGE and they will ship it out to you (most likely for free).
Problem solved, not a dollar spent.
Old Sep 12, 2011 | 06:09 PM
vmrevo9's Avatar
Veteran: Air Force
assuming that there are no boost leaks try replacing the spring in your MBC. i have the forge UNOS MBC with the hard spring and im boosting ~26-27 psi and i am not even close to maxing it out.
Old Sep 12, 2011 | 06:15 PM
wizzo 8's Avatar
Im not sure what color my spring is but I also have the forge mbc and I was able to hit 35psi with the Fp black.
Old Sep 12, 2011 | 09:54 PM
My03evo's Avatar
I know I got a few little boost leaks, I just fixed my tb seals and o-ring/unrevised threaded nut with the 2 holes in it that hold the forge bov from turning (forge dsm bov). Still need to recheck and fix any other problems before I try anything else obviously. Supposedly the car has been at 42 psi before but I don't know if it was with different parts or current ones. The wastegate actuator is currently set what fp recommends using the half the circle preload method. Going to try and do another boost leak test soon and go from there
Old Sep 13, 2011 | 06:39 AM
I still don't agree. Depending on how low you want your boost to go, you may not be able to get it that low with the HD spring in the Forge. That is why we stopped using them. One spring for low boost, one spring for high boost, change springs back to get boost low again, PITA.
Old Sep 13, 2011 | 09:12 PM
sparky's Avatar
Originally Posted by My03evo
.... I believe my black has the normal 17ish psi actuator (Vs the other 25psi one). Do I need to upgrade to the higher psi actuator to raise the boost or am I missing something simple?
Maybe I am wrong, but I was under the impression that FP only equipped the Black with the 25# actuator. Or, did they fit some of the early units with the 18# WGA? Why are you so sure that yours came with the 18 pounder?
Old Sep 13, 2011 | 09:25 PM
sparky's Avatar
....im at the point where my forge mbc is bottomed out and wont go higher than like 30psi...
So, exactly how high would you like to set peak boost on your Black anyway?
Old Sep 13, 2011 | 10:05 PM
sparky's Avatar
How many more PSI are you wanting to get out of the turbo? You say that the MBC is only giving you 30#, so how many PSI more do you want?
Old Sep 13, 2011 | 10:56 PM
My03evo's Avatar
Because my mbc lines were reversed (not my fault) and the highest it would go is like 17-18psi, fixed that, also when my meth failsafe kicks in it drops to the same psi, since it bypasses the mbc.
I want to be able to go up to 40psi, not right now but for when I go to the track or when I want to scare a friend or something and like I said I was told it was tuned at 42 psi but idk if it had the current parts or different ones in it.
Question for dave, since it sounds like you're not a fan of forge bov's what would you recommend to hold the boost, and good driveability?
ScoobySAM
Oct 26, 2008 07:35 AM
Hiboost
14
Oct 12, 2008 12:51 PM
projekt_shocker
Nov 6, 2006 09:01 PM
Sap12687
Jun 29, 2005 09:39 PM
Mooshu1221
15
Jan 6, 2005 06:43 PM
