good short shifter for evo ix??? Plz help
Old Sep 19, 2011 | 10:15 AM
mlee25's Avatar
Ive been lookin foward to get a short shifter for my evo ix.
I heard B&M is good but they dont make it anymore.
I also heard buschur ones but I didnt get the solid comment on this one.
Is there anything you guys would want to recommend??? review or anything
would be so helpful. Please show your knowledge
Old Sep 19, 2011 | 10:19 AM
Kracka's Avatar
Fidanza or http://cgi.ebay.com/ebaymotors/STEEL...item415d6b178e
They're both identical, same box, same sealed packing bag, etc. I used it and liked it on my IX.
https://www.evolutionm.net/forums/ve...o-viii-ix.html
https://www.evolutionm.net/forums/ve...must-have.html
Old Sep 19, 2011 | 10:46 AM
TWM Performance's Avatar
Hi mlee25,
We have a great quality application for your car!
http://www.twmperformance.com/shorts...rtshifters.htm
Lifetime warranty, and the same quality that you get with every TWM Performance product! If you have any questions or concerns, just let me know and I'll be happy to help!
Thanks,
Patrick
Team TWM Performance
Old Sep 19, 2011 | 11:25 AM
gsrboi80's Avatar
The $30 ebay one is as good if not better than any on the market. I'm not an EBAY parts guy at all but 100% this is not one of those "you get what you pay for" deals.
Get the EBAY piece you will not regret it neither will your wallet in this case
Old Sep 19, 2011 | 11:53 AM
shawn360h's Avatar
I just order the works short shifter with the base and shifter bushings yesterday. From what I've seen and read its a quailty product I will let you kno my thoughts when I get it and install it
Old Sep 19, 2011 | 12:48 PM
airgazem's Avatar
Works short throw shifter, base and shifter bushings!!
Old Sep 19, 2011 | 01:00 PM
wjamyers's Avatar
the ebay shifter was a big fail for me. but that's because apparently you can install it without cutting up your car but then it's not short. didn't want to cut up my car so ...
I don't remember how it shifted before but I know it doesn't shift as nice or as short as my 02 WRX with factory installed short shifter on a rebuilt trans with Legacy GT Gears.
so I wish there was a better option for me. considering the works.
Old Sep 19, 2011 | 02:39 PM
BURNALL_4's Avatar
you can use an RS shifter....15% shorter than the GSR.
Old Sep 19, 2011 | 03:38 PM
mlee25's Avatar
Thanks I just been looking foward to see the results!!
Old Sep 19, 2011 | 03:40 PM
mlee25's Avatar
Thanks for the info!!
Old Sep 20, 2011 | 06:07 AM
SmurfZilla's Avatar
I have the BR going in with the solid shifter base bushings.
Old Sep 20, 2011 | 06:30 PM
mlee25's Avatar
So you have no problem w BR?? no grinding feeling or not hard to shift??
is the height look the same as stock???
I was considering to get one of those but I just want to make sure its easy to
shift ) Thanks
Old Sep 20, 2011 | 08:35 PM
Raptord's Avatar
I put the WORKS shifter in not long ago, I had to redo the installation though because I hadn't used enough grease the first time and the shifter didn't feel good. Now that it's greased properly it shifts pretty much the same as the stock shifter with slightly shorter throw. TBH the difference in throw isn't enormous, just enough for you to notice it.
Old Sep 21, 2011 | 04:41 PM
mlee25's Avatar
So you like it so far?? ) oh now I can decide which one to go if somebody go for a review about BR ones )) Thanks !!
Old Sep 21, 2011 | 05:01 PM
JToussEVOVIII's Avatar
Veteran: Marine Corp
I also run the BR short shifter with the base and under the hood bushings. Never had a single problem and I absolutely love it. Its just a bit shorter than stock, but the stock shifter is shorter than most anyways. But the throw is much shorter than stock. Recommend!!
