Fidanza short-shifter (Evo VIII/IX)
First of all, thanks to Scheides for opening up his garage for me to work on my car and lending a hand with the install.
Great price, good quality, PITA install, and they really need to include install instructions! All said and done the shifter feels great, but the installation didn't exactly go smoothly. I got the kit on sale from Modern Automotive Performance for $59 which I think is a great deal since thats $20 off their regular price.
http://www.maperformance.com/store/p...cat=977&page=1
The kit included aluminum shifter base bushings which were very good quality and fit perfect. The kit also included 2 new white plastic bushings for the ***** that attach to the shift cables, but they were really poor quality (one cracked, one wouldn't fit) so I highly recommend reusing the stock ones (used a flathead screw driver to pry them off the stock shifter). I also had to buy a new upper pivot ball bushing from the Mitsu dealership for $14 since I didn't want to cut my stock shifter in half. I used heavy-duty marine grease on the pivot ball and the the shift cable *****.
The short-shifter comes with a removable counter-weight which was nice and really helps the shifts feel very smooth. The pivot ball is adjustable and has 2 settings. On the less aggressive setting the shifts are a bit shorter and the knob sits higher than stock (I was not impressed with this setting). I tried the less aggressive setting first because the more aggressive setting can not be used unless you hack up the plastic shifter base some which I did not want to do. I almost pulled the shifter out and returned to stock but I decided to stop being a ***** and just "clearance" the shifter base with a RotoZip. Fast forward a bit after everything was clearanced (with plastic chips and shavings all over the interior of my car and wreaking of burnt plastic) the shifter feels great on the aggressive setting. I am closer to my goal of getting my shifter to feel like the one in my S2000 (stock shifter w/countersunk knob). The shifts are now tight and precise. The throws are definitely shorter and the knob sits a bit lower than stock, but I can still shift with a 20oz bottle in the cup holder.
I just want to add that the Fidanza short-shifter is the exact same as the B&M and the eBay brands. They sell on eBay for $29 shipped with the shifter base bushings so its an insane deal!
http://cgi.ebay.com/ebaymotors/00-05...spagenameZWDVW
When you buy any of these shifters I recomend buying the follow from your Mitsu dealership:
1x Upper pivot cup (part # MR246296 Retainer+gearshif)
2x part # MR232147 tiny cups for ball ends
Good point to make. The small cups supplied did not fit so I popped off the cups from my stock shifter and placed on the new shifter so this was no big deal. You have no way to remove the Upper Pivot Cup from the stock shifter unless you cut the shifter in half. Because I did not order any of the parts I scrapped my stock shifter to use the Upper Pivot Cup.
TWM Performance
Feb 28, 2017 07:36 AM
Kracka
83
Jan 20, 2017 12:54 PM
TWM Performance
Oct 13, 2011 11:18 AM
Horus
17
Oct 1, 2011 02:47 PM
TWM Performance
EvoX 'For Sale' Engine Internals and Drivetrain
Nov 21, 2008 08:36 AM
