another turbo and still smoking
Old Sep 22, 2011 | 01:32 PM
boczo777's Avatar
long story short, 1st turbo (that came with car) started smoking bad on dyno, i bought used evo 9 turbo, went on road, 3rd gear 25psi, smoke from exhaust i could see in rear view mirror, got pissed, just bought new turbo HTA71, drove easy for 2 days, today put on road harder, 3rd gear, 4th 25psi.....smoke......
any ideas??
Old Sep 22, 2011 | 02:36 PM
llDemonll's Avatar
what color smoke?
Old Sep 22, 2011 | 02:41 PM
AWD96's Avatar
Valve stem seals. Or a piece of something clogging your oil feed line.
Old Sep 22, 2011 | 03:06 PM
BLK_EvIL's Avatar
are you running any type of catch can?
Old Sep 22, 2011 | 03:59 PM
PrimerSdime's Avatar
Did you check for oil in the intercooler?
Old Sep 22, 2011 | 05:30 PM
furby's Avatar
what made you think it was the turbo at first?
Old Sep 22, 2011 | 06:34 PM
boczo777's Avatar
Color and smell of oil,my breathers ventilates outside,when I took icooler piles they were lil wet
Old Sep 22, 2011 | 07:56 PM
If the intercooler is full of oil from the previous turbo leaking, than its going to smoke until all of the oil is burned from within the intercooler, or someone cleans it.
Old Sep 22, 2011 | 08:10 PM
boczo777's Avatar
ic pipe between turbo and icooler had more like oil film, it was not soaked or anything,
there is one stupid think i did and maybe it has any effect, on rear cover breather i put hose and it ventilates underneath engine and side breather is just plugged....
Old Sep 22, 2011 | 08:21 PM
novem's Avatar
I'd also check the oil return line and make sure there's not a restriction going into the pan.
N
Old Sep 22, 2011 | 08:31 PM
sparky's Avatar
How many miles on the clock?
Old Sep 22, 2011 | 08:32 PM
BoostINurI's Avatar
Connet the rear pcv "breather" back to the intake manifold! also take the plug off the side breather and run a line to the intake tube...your engine is building to much crankcase pressure.
Old Sep 22, 2011 | 08:39 PM
boczo777's Avatar
Thats what im gonna do tmrw,will replace cams and valve stems
Old Sep 22, 2011 | 08:51 PM
sparky's Avatar
Not valve stems. You mean valve seals, I think.
Old Sep 22, 2011 | 09:07 PM
boczo777's Avatar
well valve stem seal, anyways these
http://info.rockauto.com/getimage/ge...711792_TOP.jpg
http://www.lancershop.com/customer/p...productid=1477
