Power falls off bad around 720 HP
Old Oct 4, 2011 | 04:47 PM
  #31
Joshs EVO's Avatar
Originally Posted by R/TErnie
I'd throw a new set of Kiggly's at it for a cheap test.
After that I'd try a BW EFR 9180 with the big T4 TS hsg.
Not after what Geoff told me about the 9180. Lag doesn't bother me. It's fun as hell getting up to full boost on this turbo and the wait is killing me and I would need a new manifold anyways.
Old Oct 4, 2011 | 05:05 PM
  #32
R/TErnie's Avatar
yeah you're right.
You need to:
A) move to washington
B) buy a 4202R
C) lower your hp standards.
  #33
SmurfZilla's Avatar
Or get a bigger hotside? 1.00 housing should be enough.
Old Oct 4, 2011 | 05:07 PM
  #34
rodent's Avatar
When it falls on its face, is there a miss / hesitation / backfire?
Old Oct 4, 2011 | 05:24 PM
  #35
Joshs EVO's Avatar
Originally Posted by JohnBradley
720whp corrected or uncorrected, Mustang or DJ, and you can see valve float in the dyno sheet in the event you cant hear it. I just received a 1.15 this morning and it doesnt look that big
Aaron
That would be um uncorrected I think. It is on a Mustang.
Old Oct 4, 2011 | 05:26 PM
  #36
Joshs EVO's Avatar
yeah you're right.
You need to:
B) buy a 4202R
Actually I was thinking of doing the BW S4000. It's the older style large turbo and it seemed to do pretty good on spool and made 684 on 24 lbs up here in CO on Tobz car. Turn the wick up a bit and it would be a sick setup. So I am tossing this idea around.
Old Oct 4, 2011 | 05:29 PM
  #37
Joshs EVO's Avatar
I do not believe so. I believe it is the same scenario when we had the 4088 issue. The car would perform great until the turbo couldn't compress anymore air. Honestly the last time I really hammered on it I loved it and feels so strong. But the dyno tells a different story. I just can't tell in the seat that the HP is falling off. Maybe because by that time I am doing well over 140 Mph and my attention is on the road more than the car itself.
Old Oct 4, 2011 | 05:39 PM
  #38
David Buschur's Avatar
I'd personally like to see the dyno graph and the tune in the car, particularly the timing map.
Depending on just how drastically it falls off I have a few guesses. If it's really bad, I'd go along with valve springs but don't agree with some of the suggestions for replacements. I don't think it's the cams. It could be the twin scroll housing too, I haven't seen one yet make great power up top if they have any low end at all.
  #39
rodent's Avatar
720 should be corrected on his dyno.
Thats totally weird hp falls like that but it maintains boost at 35psi.
Old Oct 4, 2011 | 06:08 PM
  #40
EvoDan2004's Avatar
Originally Posted by TwStDeVo
honestly man, i think its the twinscroll set up. all the cars with singlescroll kits made crazy power and held all the way. id be willing to bet that if you swapped to singlescroll it would solve your issue.
i disagree very much.
Old Oct 4, 2011 | 06:12 PM
  #41
n2oiroc's Avatar
720, uncorrected on a mustang at elevation? doesnt sound too bad to me.
Old Oct 4, 2011 | 08:37 PM
  #42
JohnBradley's Avatar
720 uncorrected on a Mustang is intense. I'll explain why. Marcus that owns the 2G DSM auto that has been on Tobz dyno showed his power with a 1.20 or 1.21 correction for sea level to make it right.
So if its a new style Mustang that reads like COBB (read DJ numbers) that would still be a bunch. If its corrected and reads like DBs then thats still not shabby. I am with Dave, we need to see the dyno sheet and timing map.
Aaron
Old Oct 5, 2011 | 08:24 AM
  #43
Magnumpsi's Avatar
That is corrected. All of Tobz numbers are corrected.
Mitch
Aaron
Old Oct 5, 2011 | 08:44 AM
  #44
Can you post the dyno sheet up today? I'd like to see it. I'd be glad to look at the map too if you want to e-mail it to me or just take a screen shot and send the timing map.
Old Oct 5, 2011 | 08:57 AM
  #45
MOREPSiTEHBETT4's Avatar
you can't argue with the graphs people have posted, the twinscroll just can't keep up at high rpm.
