Power falls off bad around 720 HP
Old Oct 4, 2011 | 11:23 AM
Joshs EVO's Avatar
So I have a fully built Evo that has a problem and I would like some input into the problem and see if we can squeeze more power out of her.
List of my mods:
2.3 Stroker 9:5 CR
Buschur Stage III head
3794HTA Twin scroll with a 1.00 housing
ETS 4" IC
3 LICP
3" UICP
Kelford 280 cams
Forge MBC
Tial BOV
AEM EMS
Boomba TB
Spark Tech
E85
Magnus V5 ( dual rail. FIC 1550 primaries and 1850 secondaries) Don't bother asking why I have this.
The power climbs all the way to 8000 rpm and boost holds at like 35 lbs but then falls flat on it's face.
We think that it's possible that the Kelford 280's are done and that's what is making it fall flat on it's face. The car does lag a bit but that is of no concern right now. We want to solve the power problems.
I do live in Colorado so the altitude should be considered as a factor.
Let me know everyone's thoughts.
Old Oct 4, 2011 | 11:26 AM
thepoint4life23's Avatar
Maybe bigger cams.
Old Oct 4, 2011 | 11:28 AM
mt057's Avatar
Any pics of the Dyno graph? What ecu are you running?
GreenAWD's Avatar
I would say cams for sure, strokers LOVE big cams. The other issue is the fact your running a storker so power WILL fall off unfortunately.
Old Oct 4, 2011 | 11:31 AM
Joshs EVO's Avatar
It's possible and we need to narorw things down more before I get my 4th pair of cams.
Old Oct 4, 2011 | 11:32 AM
Joshs EVO's Avatar
Sorry I am running AEM Version 1. I knew I was forgetitng something.
Old Oct 4, 2011 | 11:33 AM
Joshs EVO's Avatar
I will try and get a graph and load it up when I get home tonight.
Old Oct 4, 2011 | 12:03 PM
06evol's Avatar
time for bigger cams!
Old Oct 4, 2011 | 12:12 PM
rodent's Avatar
What wastegates and size are you running Josh? Which spring in each?
Have you checked for boost leaks above 30psi?
Old Oct 4, 2011 | 12:18 PM
meckert's Avatar
So what kind of Pump for fuel delivery? Nothing is mentioned.
Old Oct 4, 2011 | 01:01 PM
Joshs EVO's Avatar
Buschur DP with larger feed and return lines. I think they are -8 feed -10 return. (I think)
Shawn,
The wastegates are good to go. We went through them twice with the 4088 and made sure it was the correct springs and that nothing was being pinched (gasket).
Oh and I have an ETS 3.5 Exhaust so there is no restrictions there.
Old Oct 4, 2011 | 01:08 PM
ETS Michael's Avatar
Damn Josh It's one thing after another with this car. Seems like the car should always make more power then it does.
Is this on Tobz Dyno? and 5000 ft?
I think the best guy to ask on a setup like this would be Aaron @ English Racing. He has had a very similar setup. Also post up a dyno graph.
Old Oct 4, 2011 | 01:47 PM
Joshs EVO's Avatar
LOL ya I know. It such a money pit. I was gonna email you as these are the cams I got from you. Hear of any defects with the early versions of the Kelfords?
Old Oct 4, 2011 | 01:52 PM
Nope, but there are lots of things that can happen to a CAM depending on the install. They can flatten, etc. But we would really need to see a graph to see what's going on. Does boost just fall as well?
Old Oct 4, 2011 | 01:53 PM
TwStDeVo's Avatar
honestly man, i think its the twinscroll set up. all the cars with singlescroll kits made crazy power and held all the way. id be willing to bet that if you swapped to singlescroll it would solve your issue.
