Actuator Recommendation?
Old Oct 5, 2011 | 01:13 PM
Evo TME's Avatar
hey guys, im the in market for a new upgraded actuator as my OEM actuator in busted up and totally dead. Can anybody out there recommend which actuator i should go for. im looking for something that can hold around 25psi on my stock turbo
the actuators i found are:
Forge motorsports
Forced performance
HKS
JUN
New OEM actuator
the thing is which is the most reliable and give me the results i want???
btw this for an Evo 6 Tommi Makinen Edition but as per my knowledge any actuator that fits Evo 6,7,8 or 9 will be fine??
Old Oct 5, 2011 | 01:21 PM
awdordie's Avatar
I would recommend the forge. Free lifetime warranty on them and if something ever happens they send you the parts to rebuild it and they pay for shipping, even if you weren't the original purchaser. Now that's standing behind a product.
Old Oct 5, 2011 | 01:22 PM
B.J.@ToxicFab's Avatar
I've run a Forge Actuator on my stock turbo setup with a Hallman Pro RX MBC and it held pretty well. I am now running an upgraded stock frame turbo & have an FP 25psi actuator, still using the Hallman MBC but with a stiffer spring (You have to contact Hallman for this spring). My setup holds boost very well, tapers 2 psi up top.
Old Oct 5, 2011 | 01:27 PM
Evo TME's Avatar
i actually just found out that evo 9 actuators dont fit my car but evo 8 actuators fit perfectly...
based on the reviews i read everybody is recommending the forge and the FP like you guys mentioned...the thing is i cant find any online store that sells the FP actuator for an Evo 8 they only provide the Evo 9 so i guess i should go for the forge
Old Oct 5, 2011 | 01:32 PM
I know it says Evo 9 WGA on their website but I am pretty positive the WGA fit on either turbo...Call FP & ask...
http://store.forcedperformance.net/m...Lancer-TurboHW
Old Oct 5, 2011 | 01:38 PM
Evo TME's Avatar
i will check it out but im pretty sure evo 9 actuators are different than evo 9 as per the Forge official web page
http://www.forgemotorsport.com/conte...roduct=FMEVACT
the evo 6,7 and 8 have a different product code than the evo 9
Old Oct 6, 2011 | 02:02 AM
fightex's Avatar
i've had both the HKS (the stock one that came with the GTII 7460) and the stock Evo 9 actuator crap out on me at local time attack events.
i got the Forge 25psi actuator from Mike @ AWDmotorsports and i've got nothing but good things to say about the WGA and AWD the boost comes on stronger and holds better than either the HKS and stock unit, no matter how much i cranked up the preload on either. i've seen both the FP and Forge units, and IMO the Forge has better fit and finish. HTH
Old Oct 6, 2011 | 05:52 AM
sparky's Avatar
Too bad that we live so far apart. I have a couple new Forge VIII actuators sitting on the shelf above my workbench and you could have one for free. Unfortunately though, Honduras and Bahrain are half a world apart.
Incidentally, and just to clarify, the Forge VIII WGA and the Forge IX actuator are different and cannot be interchanged on the same turbo. The VIII actuator works on VIII 16G turbos only and the Forge IX actuator will only fit on the IX 16G turbo. So, be careful when ordering. Order directly from Forge if in doubt.
Old Oct 6, 2011 | 07:57 AM
Thanks for the correction sir!
Old Oct 6, 2011 | 09:26 AM
Evo TME's Avatar
thanks a lot man, truly appreciate the freebie offer and too bad i live so far away
anyway seems like i will go with the Froge evo VIII actuator, i found an ebay seller than sells them for around USD 230 shipped...a bit over priced but he ships international
thanks alot guys hopefully il get the results im hoping for
Gazika
Jun 5, 2015 02:03 PM
Mik6222
Oct 10, 2014 08:05 PM
benIX
Feb 21, 2014 04:21 AM
spikester603
14
Nov 10, 2012 10:29 PM
SeanJhn9
Northwest Region
Jul 20, 2007 11:58 AM
