Weird poping sound from diff
Old Oct 10, 2011 | 07:01 PM
Brent_si's Avatar
A friend of mine's evo started making a poping noise when he shifts quickly. I test drove a couple evo's before I bought mine and they did this as well. Sounds like its coming from the rear diff. I had heard there is some bushing that needs to be changed to fix it but just wanted to see what everyone thinks.
Old Oct 11, 2011 | 10:04 PM
laxplayer14's Avatar
could just be his exhaust popping.. mine usually gives off a smallpop also when i shift fast depending on the rpm i shift at..i think it has something to do when the afr goes from lean rich lean (or it could be the other way, dont quote me on this) really fast..what are his mods btw
Old Oct 11, 2011 | 10:58 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Why is this in the advanced sub-forum?
If you're talking about the mustache bar 'clunk', it's normal to all unmodified evo drivetrains, dude.
Go get a mustache bar eliminator kit and call it a day.
/thread
Old Oct 12, 2011 | 12:51 AM
nightwalker's Avatar
don't need a mustache bar eliminator, just a couple bushings. easy fix
Old Oct 12, 2011 | 12:54 AM
prowakeskater's Avatar
popping*
Old Oct 20, 2011 | 05:35 PM
Brent_si's Avatar
You by chance know which bushings?
Old Oct 20, 2011 | 05:37 PM
Brent_si's Avatar
mods are hks280's, invidia downpipe, hks cat back, buschur race fmic. Its kinda slow with those cams on stock 8 turbo, mani, and o2 housing. Only was able to put down 334whp on 93oct 22psi. Those size cams need a big turbo that can handle the higher rpm's.
Old Nov 8, 2011 | 09:45 PM
block1234's Avatar
had the same issue, ordered the torque solutions bushing, still have yet to install them, so ill let you know on the updates
Old Nov 22, 2011 | 07:58 AM
block1234's Avatar
installed the bushings, and it did the job!
