exhaust design in theory
Old Jan 9, 2004 | 05:08 PM
Ron's Avatar
Ron
Originally posted by 94AWDcoupe
I have done lots of exhaust work on many different turbo cars. Some of this theory is not completely correct.
Eliminating all the backpressure in the exhaust is not necesarily always a good thing.
Backpressure and scavanging play a role in turbo spool and torque.
Can you elaborate on this? The Garret guy has very specific reasonings and explanations behind his statements, can you offer any explanation behind how backpressure helps spool the turbo, or improves torque, or improves engine breathing?
Old Feb 13, 2004 | 10:33 AM
boomn29's Avatar
So, if I'm under 400hp, and already have 2.5" exhaust....what kind of downpipe should I get?
Old Feb 13, 2004 | 11:11 AM
jid2's Avatar
As an engineer, I have to agree with the Garret guy. Everything he said is legit. Turbulent "fuild" flow, gases are considered fluids, is a completely experimental field. There are no laws, or rules or formulas for turbulent flow. Everything we know is from experimental studies. Garret knows their business.
Old Feb 13, 2004 | 12:41 PM
sir lurks alot's Avatar
When he says "avoid step changes in diameter" referring to other things you can do to minimize exhaust backpressure, does he mean going from large to small? Or does he mean small to large stepping also. I thought that stepping from small to large ,in effect, creates anti reversion chambers . I ask, because I am buying a hks dp (2.76") and want the exhaust to "step up" to a 3" test pipe and cat-back. I was hoping to get the best low end torque, (lord knows our cars have none) and still keep the top end flow going by using this set-up.
Any comments? I like this thread
Old Feb 13, 2004 | 09:05 PM
Zeus's Avatar
Originally posted by Zeus
If you re-read what Jay states, your example has to do with "scavenging" and not "back pressure". You missed the "short sentences" stating things like "to a lesser degree" and "to the point of diminishing returns". He's not wrong, just misread. I've been screaming about the myth of back pressure for years...
Not to mention Chrono's point on the ratio...
...to quote myself on this "back pressure bull****"... any way you slice it, back pressure is a bad thing in this application. A 2.5" downpipe doesn't perform "better" (if at all) than a 3" on a lightly modded Evo due to backpressure... it actually produces less back pressure due to the increased velocity of the exhaust pulse.
nismo3183
Mar 15, 2017 05:27 PM
KingTal0n
Nov 27, 2016 05:23 PM
clip14
Aug 3, 2016 04:46 AM
Geoff Raicer
34
May 21, 2009 05:29 PM
maperformance
Oct 14, 2008 04:14 PM
