acceleration noise/vibration
Old Jan 7, 2004 | 02:46 PM
budlong's Avatar
whenever i accelerate from a stand still i hear a very loud vibration from the drivers side front of the car... It starts around 2k get louder, vibrates the steering wheel a little bit, then disappears at 3k..
im hoping it nothing more than a loose bolt somewhere.. but i doubt it.
its a very high pitched sound and it onyl happens in first gear..
thanks
BUDLoNG
Old Jan 7, 2004 | 04:07 PM
budlong's Avatar
ttt
Old Jan 7, 2004 | 11:18 PM
budlong's Avatar
bump
Old Jan 8, 2004 | 06:27 AM
Dale_K's Avatar
I don't really know but I'd try to pin down whether it is an engine noise or a driveline noise. When you're in the range, swerve from side to side. Does the noise change? If so, maybe wheel bearing/brake, etc. Pull the wheel and kind of look it over. If the noise doesn't change when swerving, then motor/clutch. Why don't you just take it in to the dealer?
Old Jan 8, 2004 | 06:56 AM
mayhem's Avatar
Being that it only happens in first gear indicates it's a speed related problem which then make me thinks it's the tires. Much like the noise a lot of people notice when coming to a stop.
Old Jan 8, 2004 | 10:06 AM
budlong's Avatar
im used to road noise.. i had two itr's and a wrx before this..
the noise doesnt change when i move the wheel...
im only hoping to avoid the dealer cuz this is my only ride...and id have to rent a car if they decide to hold on to it for a while..
Old Jan 8, 2004 | 11:06 AM
Dale_K's Avatar
Afraid I'm not a good enough Internet tuner to figure this one out. I guess I'd look for something loose and if there are any mods I'd double check them first.
Old Jan 8, 2004 | 11:07 AM
budlong's Avatar
no mods to date
Old Jan 8, 2004 | 11:14 AM
4-BNGR's Avatar
I've got that too. Between 15-35mph range. IT's THE TIRES (fronts). It will go away with tire wear. Mine went away until I rotated my rear tires to the front. Drive your car hard for a while to reduce the tread compound or fix your toe and camber. I'm looking for another brand tire as we speak but will drive my ADVANS to the ground brfore I do anything.
A good turbo back exhaust set up will mask the noise under acceleration.
