idle air control valve location..vid inside!
yeah, no luck with this problem fixing itself, idle still jumps up to 2500 when the compressor comes on.
I'm going to switch the IAC back to the original part that may not have actually failed (to be honest I was just chucking parts at the problem) it tests better than these ones a lot closer to the expected result but a few ohms high. I'll hopefully do it next weekend and I'll update after.
Did you ever figure this out?
BTW I found it for $37.49, delivered on Ebay:
http://www.ebay.com/itm/370948660318
I was trying to take mine off and pressing down the clip and used my new Craftsman pry bar I just bought in an effort to "save" the clip. The clip took a piece of the IAC with it. Note to self - NEVER use pry bars on cheap plastic parts (mock away).
Called the local Chrysler dealer who used the MD628318 part number, no problem (thought maybe they had separate part numbers), and he quoted me $383.00 plus tax to order it.
So I removed it ant putted back the OEM .
I did a video of the ''clicking'' sound , i will post it later .
FYI , here is what my OEM valve and also the amazon one does . I am refering to the buzzing and clicking sound that a couple guys here mention before .
https://www.dropbox.com/s/oawk5d9wnq...%2008%2016.mov
Any updates on this?
Btw, I'm having idle issues as well (P0505 error code) and my car doesn't like to idle at night or when it isn't up to running temp. I have to give it gas when I start it and keep on the throttle until it warms up, otherwise the idle drops down to 200-ish and it dies. When it idles after it's warmed up, the idle either sits at 1450 or 1000 RPM. It also bucks very hard under light throttle in 1st and 2nd gear, and bucks lightly in 3rd sometimes. It usually starts when I hit bumps in the road. The car is cammed, but I don't know what cams are in it. I was told by the previous owner of the vehicle that the IAC has recently been replaced. I haven't pulled the sensor to test it yet, but could the issue I'm having also be from the PCV valve?
the Ebay one is now 999.99!
http://www.ebay.com/itm/370948660318?rmvSB=true
BTW, the update is, I did switch back to the original and it was still worse, so I ended up running the ebay unit and the computer eventually learned it to the point where it was almost perfect but never as good as the original when it was working right.
I think the thing to do is to buy it from Amazon:
Amazon.com: #B004 MD628318 AC571 99-05 Mitsubishi Chrysler Dodge IACV Idle Air Control Valve 99 00 01 02 03 04 05: Automotive
but do the voltage test on it as soon as it arrives and if it doesn't match the spec, send it back, until they send you one that does. If mine ever craps out, that's what I'll do.
****, here it is on ebay for $20.90 shipped!
http://www.ebay.com/itm/AC571-Idle-Air-Control-Valve-for-Mitsubishi-Eclipse-Galant-Lancer-Evo-2-4L-2-0L-/181686343053?hash=item2a4d59958d&vxp=mtr
I'm gonna buy it and see what happens. At this price I can afford to try it a couple of times.
After trying everything else I finally dropped the $325.00 for the real thing: http://www.streettunedmotorsports.co...r_1450a069.htm and all my idle problems went away. I wasted a lot of time and money trying to save a little money.
I'm running my stock IACV again that I thought had originally died. I've had no issues with it since switching back. Went through three eBay ones.
As someone who bought eBay ones, buy OE. It's a huge price tag, but you avoid all the headaches.
BriK
Sep 29, 2016 12:15 PM
araz5260
Jun 11, 2016 09:09 AM
acid7711
May 26, 2016 09:52 AM
Ant1
Apr 2, 2016 05:41 AM
