03' Evo Won't Start After Cam Install
Old Oct 31, 2011 | 07:10 PM
Blue91lx's Avatar
I'm roughly 3 hours Northeast from Williamsport.
Old Oct 31, 2011 | 07:11 PM
1d10t's Avatar
Bob Saget.
I'm sure you'll finger this out soon
If I think of anything, ill post
Old Oct 31, 2011 | 07:15 PM
Blue91lx's Avatar
http://bobsaget.com/
I appreciate it man. I'll keep this thread updated as I check things.
Old Oct 31, 2011 | 07:21 PM
AWD96's Avatar
That's so weird. Take the plugs out, spray a little starter fluid on em and try to fire it up. I did my cams and just lubed the lifters (brand new). Didn't even tick when I started it. The CAS is a big deal and a lot of issues can be had there but if you are positive it was assembled correctly then I am stumped. Compression test will eliminate the bent valve theory, even with different cams on EMS it should still start.
Old Oct 31, 2011 | 07:27 PM
AWD96's Avatar
I think you should disassemble the CAS and ensure its installed properly etc. Its got to be the issue. Also, am I the only one who sees the Bob Saget references
Old Oct 31, 2011 | 07:35 PM
bevolucion's Avatar
this might sound stupid, but did you spin the crankshaft clock wise when aligning the timing. I always do a cycle by hand before I start the car to make sure is spins correctly as advise by the manual. And make sure there is enough crank juice in your battery. Like you said everything else is accounted for, good luck.
Old Oct 31, 2011 | 07:38 PM
1sxyrxy's Avatar
lifter will be noisy at first but should start right up.
Old Oct 31, 2011 | 07:54 PM
4RETECH's Avatar
All I can say is that the small vane of the Cam sensor pick up should be facing the sensor when everything is set up at top dead center.
Also, the bleeding of the lifters will not inhibit start up, just be a little noisy untill they pump back up.
Good Luck
Old Oct 31, 2011 | 08:04 PM
Blue91lx's Avatar
That's for the help guys. I'm going to take the CAS apart tomorrow. I'm also going to double check it's ground. My tuner is local, so he offered to swing by with his laptop and check out the situation as well. I really hope I can get this sorted out. Bob Saget.
Old Nov 6, 2011 | 02:18 PM
Blue91lx's Avatar
Hey all, a little update. I looked at a different install procedure found here: http://www.evomoto.com/tech_info.php?tech_id=18
It was a lot more helpful than the video I posted. I apparently looked at it wrong and did indeed install the trigger in 180* off as the first person noted. Because I thought the way that I had it originally was correct, I did not see it as an error (obviously).
When I fixed that the car started right up, but won't run worth a crap, so I'm nearly positive it's tune related. Thanks for all of the help.
Old Nov 13, 2011 | 10:28 PM
AWD96's Avatar
I knew it!
Old Nov 13, 2011 | 11:41 PM
Blue91lx's Avatar
Haha I thought this thread was way dead. After I solved this I had a slew of other things, however, I finally got it running.
https://www.evolutionm.net/forums/ev...ar-ablaze.html
Evoaddicts
Mar 6, 2015 12:59 PM
bwanner
Jun 17, 2014 06:19 PM
OPENA(671)
Aug 12, 2013 11:36 PM
mistergomez316
Jul 1, 2012 10:03 PM
khmerguyx
Dec 30, 2011 12:03 AM
