Issues With Typhoon Intake?
Old Feb 21, 2004 | 11:25 AM
  #31
eve-slow's Avatar
I don't think that the actual design of the filter is the problem. Like stated before, there is just too much air passing the sensor. Just get a dynoflash, it is definetly the best modification on my car, and one of the cheapest!
Old Feb 23, 2004 | 10:59 AM
  #32
Capt_Crunch's Avatar
Tried the sock that K&N sent. Still too much air. Went back to the stock intake and drop in. Everything is working
Old Mar 26, 2004 | 07:49 PM
  #33
wrex4x4's Avatar
WELL I HAVE THE SAME PROBLEM AS EVERYONE HERE I CALLED k&N THEY SAID AFTER 200MILES THIS CORRECT ITS SELF OK AND I PETERCOTTON TAIL I BELIVE k&N ARE FALSE STAMENTS ON THE PERFOMANCE ON THIS PRODUCT SO WHATS UP EVERONE LETS SEE WHAT WE CAN DO.HEADERS,GHL EXHUAST,GREEDY BOV,SAMCO HOSE INTERCOOLER,TYPOON INTAKE.130MILES TO GO AND SEE IF IT RUNS LIKE THE BAT OUT OF HEEL SHE USE TO BE.
Old Mar 27, 2004 | 11:24 AM
  #34
I would be interested in seeing what happens after your 200miles. Keep in mind the ECU learns pretty quickly...faster than other ECUs I have seen, so it should be able to adjust after 10-15 minutes of driving. So I am not sure if driving 200 miles will help, especially when my fuel cut was hitting on every WOT, then I eventually through a code/CEL/SES. I think I drove about 250 miles on the intake and it did not change anything
Anyway good luck. BTW, my car has been performing great since I went back to the stock intake with the drop in.
PS, you might want to avoid using all caps, people might think you are "yelling".
Old Apr 13, 2004 | 03:37 PM
  #35
NEMES!S's Avatar
I have an aftermarket intake, does this fuel cutout feel like
wastegate control under extreme loads?
Old Apr 13, 2004 | 03:54 PM
  #36
BaLListic_EVO's Avatar
yeah my butt dyno has been telling me a problem for months now.... yet i havent quite got around to switching the stock box back. Right now i believe i will simpily because of the crapass 9.06 i ran at the drag strip that really raised an eyebrow for sure!.......
Old Oct 30, 2004 | 10:07 PM
  #37
smp3000's Avatar
Wow, I installed the K&N today and ran the track tonight.... VERY dissapointed. The car ran so dog slow and yes I feel the fuel cut. My best run was a 16.7 while a stock evo there was running 13.8 with horrible launches. I felt like an ***.
WTF do I do? has there been any progress?
Old Oct 30, 2004 | 10:25 PM
  #38
evoego's Avatar
Registered User
man if u ran a 16.7 in an evo the typhoon is not your problem. I havent had any probs with mine, but I think I will get around to putting the stocker on just to compare for you guys. tuning was donewith emanage and e-01 BC, TB exh, needs a good tune now.
Old Oct 30, 2004 | 10:51 PM
  #39
smp3000's Avatar
Everything is installed right, and there are no air leaks.... It just seems that the car is freaking out since there's so much air and is DUMPING a tond of fuel. I went through a half tank of gas in like 40 miles of driving- this is not normal.
Update:I tried resetting the ECU- this did nothing.... I tried the garbage bag trick (taping a plastic garbage bag to 65-70% of hte intake therefore limiting it's surface area) and it really helped a lot... This proves the fact that it's the amount of ariflow that is killing it.
Old Nov 1, 2004 | 10:39 AM
  #40
Deepseadiver's Avatar
I have the K&N Typhoon. Not real happy with it because of all the sh*t that I have been reading about it, It sounds good, and I havent had any huge problems with it. Should I put the stock box back on or switch to something else HKS RS intake?? any thoughts.
Old Nov 1, 2004 | 10:42 AM
  #41
smp3000's Avatar
I am putting the stock back in tonight- and going with the perrin short ram. I havne't heard anything bad about it, but it looks good and usually as long as you dont' see threads about it being bad it's just fine lol
Yes I'd go with the injen, the HKS, or the Perrin. I should have the Perrin installed by midweek.
Old Nov 1, 2004 | 11:47 AM
  #42
erioshi's Avatar
The K&N Typhoon won't work without engine management. I did some wideband testing after installing one and the AFR's were war too rich. After some dyno tuning it's been alright, but it does feel like I've given up some torque for top end HP. I have even considered switching back to the stock airbox a few times, but haven't done that yet.
Old Nov 1, 2004 | 11:48 AM
  #43
smp3000's Avatar
yup- that seems to be the concensus. I just ordered the perrin short ram- and in the meantime will be rocking the stock again.
Old Nov 1, 2004 | 12:18 PM
  #44
I had Al from dynoflash tune my car when it was bone stock. After I put on the Typhoon Al said he will not waste his time tuning my car with that intake on.
Old Nov 1, 2004 | 12:38 PM
  #45
djtmotorsports's Avatar
I've had a Typhoon installed since they came out and have no issues yet. I have a full 3" TB exhaust, a Hallman MBC, and an E-Manage. 310WHP and no CEL's or fuel cut issues.
