Is the turbo oil feed from the head pressurised??
Old Nov 21, 2011 | 12:19 PM
craigybaby37's Avatar
Hi all just after a little advice to find out weather the factory turbo oil feed from the head is pressurised, even if it's a small amount or is it just another drain point from the head so to speak??
Just I have my gt30 turbo and have purchased the correct oil supply line and it come with a restrictive and it only has a very small hole in it for the oil to flow through I would say no bigger than 2mm would you say this is right??
Thanks
Craig
Old Nov 21, 2011 | 12:36 PM
okevolutionVIII's Avatar
Thanks
Craig
If it's a ball bearing turbo, it'll be fine.
Old Nov 21, 2011 | 12:44 PM
BigT's Avatar
Ofcourse it is pressurized.
Old Nov 21, 2011 | 12:49 PM
todd6027's Avatar
its pressurized hence the restrictor as bb turbos dont need pressure to float the shaft like std type journal bearing
Old Nov 21, 2011 | 02:48 PM
Thanks for the replys I was just trying to get my head round it and how it works, what kind of pressure would you see from the outlet from the head then??
Old Nov 21, 2011 | 02:51 PM
BigT's Avatar
Pressure at the head is a lot less then at the oil filter housing. I would say, a turbo fed from the head does not need a restrictor. (educated guess)
BUT, I would much rather feed it from the OFH with a restrictor and inline filter. FP has a nice all in one unit.
Old Nov 21, 2011 | 06:04 PM
Save yourself several hundred dollars from buying an FP piece and run it from the stock location with the restrictor and an inline filter and you'll be good to go, same setup I have.
Old Nov 21, 2011 | 06:48 PM
smack_evo's Avatar
todd6027 has it right. you only need real pressure for journal bearing/non-ball bearinged stock body turbos. i believe robert at fp said mitsu recommends a minimum of 43psi. i know the info is on the fp site.
if you run full head pressure(non-restricted) though a ball bearing turbo you'll push seals
Old Nov 21, 2011 | 06:56 PM
WHTEVO's Avatar
Yes the head is pressurized. I have seen about 60psi of oil pressure at the head.
Just run it to the stock location and you'll be fine since it has restrictor in it.
Aaron
Old Nov 22, 2011 | 03:33 AM
Some really helpfull info here people thanks very much, the user of the turbo before me didn't have a restrictor they just used the factory banjo bolt setup so I have to hope the seals are good. Will keep the setup I have which is stock oil feed with restrictor at the turbo.
Thanks again for all the help
Craig
Old Nov 22, 2011 | 06:29 AM
94AWDcoupe's Avatar
I have run BB turbos from the head for years without restrictor. No issues. The restrictors were originally designed for oil pump housing where oil pressure can exceed 100psi when cold. FP sells different size restrictors depending on where the line will be run from. Dont quote me on sizes but I think they are .080 at oil housing and 1.20 from head.
Old Nov 22, 2011 | 06:43 AM
gsrboi80's Avatar
Yea I have no restrictor to my BB turbo. Been that way over 2 years now. No issues
Old Nov 22, 2011 | 06:59 AM
NOMIEZVR4's Avatar
Good info thread
Old Nov 22, 2011 | 02:21 PM
Originally Posted by NOMIEZVR4
Good info thread
Yea I think that aswell, not something I have seen discussed about the oil pressure from the feed to the turbo so figured I would ask the question.
To the people who have run non restricted feeds to there BB turbos with no probs that's good to hear as I don't know how long mine was previously run for with no restrictor
Old Feb 3, 2013 | 09:05 AM
DagYo369's Avatar
Bringing an old thread back to life! I am replacing my stock evo9 turbo with a pte 5858 journal bearing can I use the stock feed out of the head or should I tape in to somewhere else? My friend swore he read somewhere that is a bad source to pull the feed from??? thanks in advance!
