Will this fit?
Old Nov 22, 2011 | 05:51 AM
jonnyktm's Avatar
Question Will this fit?
If the eclipse and the evo both run a 4g63 then won't some parts be able to be swapped between them? My main question is cams, I have an eclipse with Crower 272's and if they will fit on an evo then I want to swap them straight across. What about pistons as well?
I guess for future reference and maybe even Sticky purposes, what thing's CAN be swapped between the eclipse and evo 4g63?
Thanks guys.
Old Nov 22, 2011 | 06:02 AM
PaperClip's Avatar
I believe the eclips cams are thinner... not to mention the evo motor is @$$ backwards compared to the eclips. Don't quote me on this though as I'm not too familiar with the eclips 4g63.
Old Nov 22, 2011 | 12:20 PM
dastallion951's Avatar
i dont think they fit but tell ya what keep ur crower 272s in yours, if you have an evo 8, pm me ive got some hks 272 cams im tryin to get rid of. Let me know. But as far as i remember a lot of the specs on the valvetrain, are different from eclipse to evo.
Old Nov 22, 2011 | 12:44 PM
jonnyktm's Avatar
Yeah I am not sure what is exactly different, but the trans is on the other side. Maybe I'll ask this same question on the DSM forum and see what I can learn, and I'll post what I find.
Old Nov 22, 2011 | 11:02 PM
okevolutionVIII's Avatar
You would have to swap the intake cam on the DSM onto the Evo exhaust side and vise versa. You would also need to cut a notch in the DSMs intake cam 90*s from the other notches for the cam angle sensor to line up properly so yes, they can be swapped.
