Flywheel Bolt Questions
Old Nov 27, 2011 | 07:10 PM
Ralliartize It's Avatar
I'm going back to a more conservative set-up vs the Exedy Twin I have now.
1. Does the Exedy Twin set-up use the factory bolts to bolt the flywheel to the crank?
2. If not, what size are the factory size bolts that mount the flywheel to the crank?
3. What size are the bolts that mount the flywheel to the pressure plate? (These are different bolts obviously)
Thank you in advance.
Old Nov 27, 2011 | 07:56 PM
n2oiroc's Avatar
flywheel to crank is 12mmx1.25 and about 17mm long. i looked and cant find any high strength bolts with a short enough head to replace the oem bolts.
Old Nov 28, 2011 | 12:31 AM
evilempire76's Avatar
Yes it uses factory bolts to bolt to flywheel.
You will need new pressure plate bolts though.
http://www.streettunedmotorsports.co...plate_bolt.htm
I would also recommend a factory oem throwout bearing.
http://www.streettunedmotorsports.co...ut_bearing.htm
dsmdion
Dec 15, 2015 06:08 PM
JBAutosports
EvoX 'For Sale' Engine Internals and Drivetrain
63
Nov 18, 2012 05:01 PM
bubba17
Feb 17, 2012 10:30 AM
MitsuJoe
Oct 24, 2008 06:12 AM
Speed Element
Jan 9, 2007 03:09 PM
