hp from twin walbro setup??
Old Nov 28, 2011 | 06:21 AM
boostedup's Avatar
hi is any one running a twin walbro set up? i am interested to see whatg sort of power my fuel system will support, i have a 255 intank pump feeding a surge tank which has 2 inline 255 walbro pumps, injectors arent decided yet but they wll be big enough, looking at ID2000 (ideas of the cheapest supplier for them woujld also be appreciated) i have a return line going back to the surge tank and then from there to the fuel tank, i have a dedicated 12v supply straight to the battery.
i am looking at using the likes of a fp3794 on e85 around 35psi boost on 45psi base fuel pressure or there abouts so fuel system max power will be at about 80psi fuel pressure.
interested to hear if any one is running a similar set up and what sort of power you might have made with it and if you have found the limits of the system, cheers guys (am chasing around 800rwhp)
Old Nov 28, 2011 | 06:55 AM
RjRacing05's Avatar
Twin 255lph in-tank set-up with proper fuel lines, injectors, and fpr will do you just fine.. no need to complicate the system and have the added noise of inline pumps as the twin in-tank set-up has been proven past 1000whp
Old Nov 28, 2011 | 07:14 AM
milford's Avatar
it sounds like you already have a capable fuel pump set up going on? my buddy has an almost identical set up and it supported a 3582 on ethanol at 35psi no problem. his set up consisted of the ID2000's as well. He was making a hair over 600 on a DJ i believe.
mrfred
68
Jul 13, 2017 11:22 AM
SurfGuruJeff
Jan 26, 2017 05:34 PM
razorlab
Dec 6, 2016 08:45 PM
ryukinevo
Nov 13, 2015 12:00 AM
KevinD
Dec 9, 2010 08:16 AM
