Aftermarket oil cooler vs stock
Yes, this specific bracket is by the firewall. I was just use this picture as an example to show what the brackets looked like after I powder coated them. Believe it or not, powder coating isn't all that hard.
Rough powder coating howto:
You need some type of media blaster to clean the parts, an oven, a powder coating system, and a face mask.
I used the glass bead machine at work to clean the parts and also borrowed an oven from them. I bought the powder coating system and powder for 60$ from Harbor Freight. I coated the parts and baked them in my garage. I powder coated every bracket I could get my hands on while the engine was out of the car.
Exactly! Thanks
-Bink
Exactly! Thanks
-Bink
Exactly! Thanks
-Bink
Exactly! Thanks
-Bink
since installation link from MAP was broken, here is another
http://www.maperformance.com/blog/ca...ations/page/2/
it does look great. but is this the actual mount for the oil cooler? thats what im confused about lol
-Bink
thank makes sense haha thanks. now that i know that MAP utilizes stock brackets, i might go STM and save significantly more money....
Here is the pic of my STM oilcooler using stock mounting brackets. I used 2 little pieces of 1" square aluminum and two longer bolts.
You can see them in the upper right of the pic. Notice the 45 degree instead of a 90 on the bottem.
PS. I also don't want to hear about the top hose being too long.
FWIW, MAP's oil cooler, is a better oil cooler. It's also more expensive since it bolts right up as opposed to STM's which requires a bit more work.
-Bink
Here is a pic of my car racing up 7.5 miles of uphill without an oilcooler. Oil temps were never affected. Now i wouldnt' run any 20 min races without on but i think the idea of better or worse is not really all that important unless you guys are doing some serious racing. (that being said, B&M has been doing this for alot longer then most company's) I think people think if it dosnt' have an exotic name that it isn't good (why do you need an oilcooler that is made in Sweden?). We do still make some good ol stuff right here in the USA!
As easy as it was to make the stock brackets works. I think that the stock location sucks for anyone that might crash once in a while. I will be mounting mine up by the rad, like in that other thread.
What were your temps beforehand?
Does the oil cooler keep temps down or prevent them from raising for a longer time?
Is the stock oil cooler good or garbage?
FWIW the setrab unit that is in the MAP kit is just a rebadged derale cooler
http://www.jegs.com/i/Derale/259/52510/10002/-1
$165
ams also uses this core in their kits
$165
It is pretty easy to overheat the oil when you are on the track with the stock unit.
when i had the stock unit, i could drive the car on the track for about 10 minutes before i had to back off and take some cool down laps. I wouldn't let the oil temp get over 270*.
now that I installed the larger cooler (same core as MAP/AMS), i do not need to take any cooldown laps, although the longest ive driven the car on the track at one time is 30 minutes.
