Aftermarket oil cooler vs stock
Old Nov 28, 2011 | 09:41 AM
bnr34rb26dett's Avatar
Question Aftermarket oil cooler vs stock
Im planning on getthis this \/ for my build evo.
http://www.streettunedmotorsports.co...proclassic.htm
i have also read this post by STM.
https://www.evolutionm.net/forums/ve...ooler-kit.html
which seems to be closed now for some reason
i was wondering if anybody had hands on experience with this unit or upgraded oil coolers in general. does it make that big of a difference? Any test results?
how about the mounting of this particular unit? I see that STM fabbed their own mount. does this mean i wouldnt need the stock cooler brackets at all?
Old Nov 28, 2011 | 09:44 AM
TurboTravis's Avatar
It wont fit on stock brackets. It's a cheap alternative to replacing the expensive OEM unit. I use the same one, works great
Old Nov 28, 2011 | 09:57 AM
gsrboi80's Avatar
Got a damn hole in mine. Will likely end up with the STM kit or similar and mount it up myself.
For now I just deleted it No biggie
Old Nov 28, 2011 | 10:04 AM
how did u manage to do that lol
Old Nov 28, 2011 | 10:23 AM
B.J.@ToxicFab's Avatar
The hole or deleting it? Haha...If you are talking about the hole, probably a rock or something hit it. To delete it, all you need to do is remove everything & find 2 plugs that fit where the return & feed lines thread in and bam done. For a drag race only car, an oil cooler really isn't needed, weigh reduction!
Old Nov 28, 2011 | 10:28 AM
Teal2nnr's Avatar
I bought the Setrab one from MAP.....its a lot bigger then stock, so i'm assuming it'll be a lot better...and its a good brand...also a bit more then the STM one in that link.
I'm sure that one will be fine, can't see it being worse.
Old Nov 28, 2011 | 10:47 AM
gsrboi80's Avatar
Yea for the hole something pierced it could see it clear as day.
As for deleting it bought these
http://www.streettunedmotorsports.co...ler_delete.htm
Old Nov 28, 2011 | 11:00 AM
yea i meant to say how did u destroy the cooler. lol
Old Nov 28, 2011 | 11:04 AM
http://www.maperformance.com/map-oil...ck-xx-evo.html
this?
its a very nice piece but $$$$$$$$$$$
Old Nov 28, 2011 | 11:21 AM
LCS's Avatar
LCS
I have the MAP kit. Came complete, with new brackets, hoses fittings, etc. Was a breeze to install.
Old Nov 28, 2011 | 12:37 PM
y did u decide to pay that extra $200 to go with MAP instead of STM? does it cool that much better?
Old Nov 28, 2011 | 05:10 PM
blknblubkrdude's Avatar
When I build my engine, I definitely will be going with the MAP cooler. It is a high quality, complete kit, with awesome fitment.
Old Nov 28, 2011 | 05:24 PM
joey110892's Avatar
i have the stm kit on my car. it fits great and havent had any issues with it
Old Nov 28, 2011 | 05:34 PM
Sirnixalot's Avatar
I made my own kit from summit and used a larger Longacre/B&M cooler (albeit i am using an Evo8 OFH on an Evo3). My fittings are push fit but you get the idea.
(don't mind the mess)
I realize everything is on the "wrong" side for you guys but you get the idea I am not sure about how low the Evo 4-9 oil pan sits but on my Evo3 the 90* fitting is a almost at the same level with the bottom of the pan I think a 120* fitting would have given me slightly more clearance. Batinc sells the metric banjo to -AN hose fittings but they are pricey. If you track the car...whats $80 extra for your oil supply?
Oil cooler BMM-70266, $76
-8AN to 1/2" NPT straight adapter FRA-481688 $6 each (you need 2)
18x1.5mm to -8AN fittings FRA-460818, $4 each (you need 2 as well as 2 18mm crush washers)
Hose ends and hose of your choice
Old Nov 28, 2011 | 07:08 PM
/\ very nice.
and that is exactly why i cant justify spending $400 for MAP kit.....
