Clutch Or Shifting Problems Need Advice
Old Nov 30, 2011 | 01:04 PM
elhuberto's Avatar
Hey everyone I just got my first evo a lil over a week ago and having some problems shifting
Its a lil hard to get in gears when standing still and also when at high rpms plus when I am coming to a stop and I go to shift into 1st while still rolling I can feel the gears threw the shifter just feel like its never fully working
I adjusted the clutch screw and it helped a good amount but now that bolt is almost at the end and I still am having the same issuses.
Is the clutch shot or is their something wrong with the slave or master cylender
Going to blead it tonight but I don't think that's the problem
Old Nov 30, 2011 | 01:10 PM
m4tt VIII's Avatar
I don't know a lot about transmissions, but it may need a rebuild. What kind of mileage is on the car? Also year and 5 or 6 speed?
Old Nov 30, 2011 | 01:34 PM
tristate's Avatar
Do you get any grinding with it or just rough to shift?
Old Nov 30, 2011 | 02:14 PM
elhuberto's Avatar
Its got 60k on the car and not really grid if I shift without mashing the pedal to the ground the it will give a lil grind into 2 and 3 and just rough to get into the rest of the gears if I mash the clutch to the floor threw all the gears its a lil hard almost like a mustang where it has to pop into each gear
My car before this was a built Honda and I was able to go threw the gears with 1 or 2 fingers gears just slipped in.
Never drove a cable shift before but it just don't feel
right like I said it almost feels like a mustang where the gears click in
Feels like it needs to grab sooner but the pedal adjuestment like I said is allready almost maxed
Old Nov 30, 2011 | 02:20 PM
elhuberto's Avatar
And its a 5 speed
Old Nov 30, 2011 | 04:52 PM
elhuberto's Avatar
Any one have this problem? Or know how to fix it
Old Nov 30, 2011 | 07:46 PM
elhuberto's Avatar
Anyone?
Old Nov 30, 2011 | 07:48 PM
tscompusa's Avatar
look for some fluid leaking from either the slave cylinder or master cylinder.
Old Nov 30, 2011 | 09:06 PM
drb's Avatar
drb
Try adjusting the clutch some more, it sounds like that might fix it at least until you can replace the clutch. Send me a PM with your e-mail and I will send you a "how to" on the clutch adjustment.
Drain and replace the transmission fluid with some high quality transmission fluid. I like Redline MT-85, do a search for other popular transmission fluids.
Like Tom said check the slave and master cylinder for leaks.
Dan (drb)
Old Nov 30, 2011 | 09:16 PM
drb's Avatar
drb
Since you just bought this car check to be sure that it does not have a aftermarket Clutch Fork Stop that is improperly adjusted - see picture.
Attached Thumbnails Clutch Or Shifting Problems Need Advice-stm-clutch-fork-stop.jpg
Old Nov 30, 2011 | 09:39 PM
fasolxpl's Avatar
i got evo 9 mr same problem but i got no grinds just shifts rough to 2nd gear only.. its weird feels like something is swollen inside
Old Nov 30, 2011 | 09:56 PM
johnnydemz4G63's Avatar
when was the clutch replaced? i had the same problem, is it locking you out of the gears?
Old Dec 1, 2011 | 06:05 AM
elhuberto's Avatar
Just check the slave and master and no leaks goin blead it today just to make shirt theirs no air and maybe change out the fuild hopeing that will help
Old Dec 1, 2011 | 06:14 AM
elhuberto's Avatar
Not locking me out just a rough shift almost like a 5.0 mustang where ya Gatta click it in
Old Dec 1, 2011 | 06:23 AM
waylonmunoz2005's Avatar
I'm having the same prollem. Sometimes I can't get into 2nd at all. I was thinking that maybe my syncros are going out but I'm not sure. I have a stage 2 act clutch. Hopefully theirs a fix?
