Transfer case leaking ACD fluid out of top
Old Dec 3, 2011 | 03:15 PM
volkevo9's Avatar
My transfer case is leaking acd fluid out of the top. I have to refill it almost every day.The only thing that has changed is I wrecked it a little and had to put a spare on because it bent the wheel. DOES ANY ONE KNOW WHAT IS WRONG???
Old Dec 4, 2011 | 01:18 PM
volkevo9's Avatar
help
Does anyone know anything about my problem
Old Dec 4, 2011 | 03:50 PM
Evoloved's Avatar
Sounds like you may be leaking ACD fluids aka ATF look at the reservoir and see if its below fill ...
Old Dec 4, 2011 | 05:18 PM
volkevo9's Avatar
Yes
I know im leaking acd fluid, but why am i? I refill the resi every few days.
Old Dec 4, 2011 | 05:24 PM
thedru13's Avatar
Check the banjo bolt on the top of the tcase.. Might be lose..
Old Dec 4, 2011 | 06:13 PM
Liqquid's Avatar
this, it's a large banjo bolt on the top of the t-case, it also uses two copper crush washers so if those are ruined or missing it's gonna leak, the pump is going to push fluid out from there every time you drive the car
Old Dec 4, 2011 | 06:23 PM
4RETECH's Avatar
Exactly,
just check the banjo bolt on top of the case.
Old Dec 4, 2011 | 10:36 PM
fireroasted's Avatar
OK, Most likely what you have the other guys are on target, but I have a long story about the Tcase. Not much of it helpful here, except to make sure folks understand there is a reservoir at the top of it. You can't see it in the car, nor reach it.
You can see from my TCase pic. Tape around the center of the TCase, and if you look closely you will see that this is holding on a rectangular cap. On my salvage purchased EVO that cap was never installed with the 4 bolts expected. So, this seems to have been leaking for some time. However, I was always so **** and up to date with my fluid service that I masked the problem. (always filling back up before it got too empty essentially) Recently the TCase failed on me (that's why its on a palette to Shep's). When I was removing the TCase that cap, I never new anything about, fell out of the car. I hadn't change the fluid in a year, and that meant I was no longer covering up for this issue.
You can clearly see the caked on oil dirt residue on the top of the TCase that this has been going of for some time. At the track I noticed the "death whine" and got under the car to check for oil. I made the conclusion, incorrectly, that no oil, meant I wasn't leaking any, and that it was full of oil. For some moronic reason I didn't open it to 'top it off'. I cut my day short and drove home. I only got about 100 miles and boom.
See where the fluid is coming from, and if you can reach above the drive shaft forward onto the rear of the tcase for signs of that reservoir leaking.
Old Dec 5, 2011 | 03:40 PM
volkevo9's Avatar
Thank you
Thanks for the advice!
roblee8908
Nov 3, 2013 08:44 PM
123kid
Mar 8, 2013 07:02 AM
BEKevo
11
May 6, 2012 07:29 PM
211Ratsbud
19
Aug 16, 2011 08:52 PM
hahnsolo
Jun 22, 2010 08:53 PM
