9.8 vs 10.5 hotside difference
Old Dec 6, 2011 | 11:29 AM
stunt2's Avatar
what's the difference between 9.8 and 10.5 hotside, flows better, spools better or why are ppl swapping them ?
Old Dec 6, 2011 | 01:13 PM
211Ratsbud's Avatar
more top end from a 10.5. Slightly quicker spool from a 9.8. Less back pressure 10.5. More back pressure from a 9.8. see the trend?
The loss in spool is small, and the gain in HP is relatively small aswell. Ive heard about 10hp gain from a 10.5 housing.
Old Dec 7, 2011 | 12:44 PM
thepoint4life23's Avatar
i think you can make more over all power on a 10.5 hot side
Old Dec 7, 2011 | 09:42 PM
awdordie's Avatar
what 211ratsbud said. it also has a single wg flapper vs the 9.8 twin flapper. the larger single puck of the 10.5 flows better than the 9.8 dual puck design which helps with boost creep. the larger area also helps hold peak boost longer and it doesnt taper and fall off as soon.
Old Dec 7, 2011 | 09:48 PM
EV0L-IX-MR's Avatar
Originally Posted by 211ratsbud
more top end from a 10.5. Slightly quicker spool from a 9.8. Less back pressure 10.5. More back pressure from a 9.8. See the trend?
The loss in spool is small, and the gain in hp is relatively small aswell. Ive heard about 10hp gain from a 10.5 housing.
+1
Old Dec 8, 2011 | 03:05 AM
stunt2's Avatar
thanks guys
Dakota Evo
Apr 4, 2017 02:18 PM
Awd_evo
Sep 18, 2013 04:21 PM
DisgustipatedM3
Mar 1, 2013 02:50 PM
dprez25
Dec 31, 2012 05:09 AM
pettyboy69
12
Jan 18, 2011 10:02 PM
