breaking in new shortblock ** couple questions on rings seating**
Old Dec 12, 2011 | 06:59 AM
binky's Avatar
Yeah, you definitely don't need to crank for that long.
I cranked it for 8 seconds 3 times, in order to prime my oil line going to to the turbo.
I then connected my CAS back up, cleared the check engine light (which came on because the CAS was disconnected) and she fired right up.
-Bink
Old Dec 12, 2011 | 07:00 AM
psphinx81's Avatar
Originally Posted by TurboTravis
Start the engine, check for oil pressure, leaks, etc. Let it warm up and start WOT tuning.. Change oil sooner than later.
this.
beat the **** out of it.
my motor had exactly .9 miles on it when it went onto the dyno and ran 40psi through it.
Old Dec 12, 2011 | 07:36 AM
Svendiesel's Avatar
I mentioned priming the oil solely for the turbo so its not a dry start if its a new turbo.
Old Dec 12, 2011 | 07:58 AM
n2oiroc's Avatar
Originally Posted by psphinx81
this.
Beat the **** out of it.
My motor had exactly .9 miles on it when it went onto the dyno and ran 40psi through it.
Old Dec 12, 2011 | 09:28 AM
longdingydong's Avatar
already got a case of brad penn break in oil. thanks for all the advice guys getting pretty excited to fire this baby up. getting oh so close
btw: i got a oil pressure gauge. whats base oil pressure? no balance shafts if that matters.
Old Dec 12, 2011 | 09:40 AM
binky's Avatar
My base oil pressure with no balance shafts on my built motor is between 21-25 PSI at idle.
-Bink
Old Dec 12, 2011 | 09:46 AM
ok thanks Bink
Old Dec 12, 2011 | 09:51 AM
binky's Avatar
ok thanks Bink
NP man!
Good luck firing her up!
-Bink
Old Dec 12, 2011 | 11:31 AM
todd6027's Avatar
prime the oil pump before you put the timing belt on , oil cooler connected , blank the feed to the turbo ( you dont want oil pressure in turbo with out it spinning ) put the two timing belt tensioner bolts in hand tight (stops oil coming out through one of the bolt holes )14mm socket and a drill on to the oil pump sprocket , turn clockwise till it primes the full system.
when you fire it up check for coolant /oil leaks if alls ok run @ 2k for 15 to 20 mins mins , change oil and filter use running in or mineral oil suitable for turbos . drives it sensibly use boost and revs but no wot throttle stuff , change oil at 250miles / 550 /850 using mineral
Old Dec 12, 2011 | 06:10 PM
kouzman's Avatar
i followed the Buschur approach and thats also what my mechanic did...
Within 2-3 miles (drive around the shop) and ony oil change we got 560 awhp on pump and the next day i went to the track and ran my first 130 mph pass! The motor had less than 100 miles in total in cluding dyno time, and driving to the track...
Within 200 miles i was running 30 psi on pump at the track pass after pass...
Stevo9267
Feb 23, 2016 09:22 AM
Blue91lx
30
Jul 2, 2012 04:07 PM
no0odlez623
Jan 23, 2009 06:09 AM
BOOSTonHanD
Feb 25, 2006 08:27 AM
Evo_doer
May 6, 2004 11:55 AM
