cam break in?
Old Jun 17, 2005 | 07:58 AM
BOOSTonHanD's Avatar
cam break in?
hi im gettin hks cams installed today and im not sure on a proper breaking in procedure or time. i have to drive my car back home and its a hour drive so i dont want to mess thing up on the way home. please let me know what i need to do to make sure the do get broken in properly. thanks
Old Jun 17, 2005 | 08:26 AM
scott88vr6's Avatar
I don't really think there is a break in period. As soon as I installed mine, I started it up and let it run for a bit and then drove it an hour home. You will be fine.
Old Jun 17, 2005 | 08:35 AM
Chris@nolimitmotors's Avatar
no such thing
Old Jun 17, 2005 | 08:43 AM
PVD04's Avatar
There is no break-in period. Most people take it easy at first to make sure there weren't any installation issues. Just pay attention to your car and listen for any strange noises. Also, you probably don't want to go too crazy until you get retuned.
-Paul
Old Jun 17, 2005 | 08:44 AM
GinuwineEvo8's Avatar
Some places recommened 500 miles or so before you take it up to/past redline ... It wouldnt hurt .. a couple miles here to save you a pocket full of dough later ... Sort of like preventive maintanence!But then again - with such a mod that opens up so much power - I myself would probably be tempted to just go wide open lol
Old Jun 17, 2005 | 11:07 AM
cool thanks! i didnt know if there was a break in but at least now i know that i should have no problem, and it gives me a peace of mind! thanks
Old Feb 25, 2006 | 04:52 AM
Drift4's Avatar
I was told by several race engine builders: Use new oil+ filter, and thoroughly clean your new camshafts and apply a high-quality assembly lube (not motor oil) to all contact surfaces. Then engine needs to be primed to allow oil to completely circulate, for 15 seconds no more than 30 sec with 15 second interval. You could also pour the last quart of oil from the top since valve cover is off the head. Install valve cover to proper torque spec. DO NOT let it idle....as soon as the engine starts. It is essential to run the engine no more than 1500-2000 RPM for at least 20 minutes for proper camshaft break in.
Because the camshaft and lifters (after lifters have been bled and cleaned) are primarily get better lubrication by the splash of oil from the squiters, any RPM below 1,300 may result in insufficient lubrication and may cause cam lobe premature wear or scoring.
The high RPM also allows the lifters to rotate quicker and seat properly to the camshaft during this critical break-in procedure. During the first 20 minutes, carefully monitor oil pressure (if you have and oil pressure gauge) if any problems arise, shut down the engine immediately.
Old Feb 25, 2006 | 08:27 AM
evorace's Avatar
Put em in and go. Listen when you first start it to make sure everything is installed properly. Aside of that, there is no real break in procedure for cams.
Welcome2GoodBur
Mar 15, 2017 04:12 PM
benIX
May 25, 2016 10:10 AM
Blue91lx
30
Jul 2, 2012 04:07 PM
MaxKanisha
Jul 2, 2007 08:45 AM
RomansEVO8
Sep 7, 2006 02:10 PM
