Question : driveshaft to Tcase rubber/oring
Old Dec 28, 2011 | 01:16 PM
marcusE's Avatar
Hey, random question that needs to be answered quick..
The weird shaped rubber ring that fits between where the transfer case and the driveshaft meet.
When I removed my driveshaft from the tcase I noticed the O ring was torn /seperated cleanly from each other.. This isn't how it should be correct?
The one in the picture
The one that fits HERE :
You can see the outline of where the oring is.. Almost shaped like an exhaust gasket
Old Dec 28, 2011 | 05:08 PM
marcusE's Avatar
ttt anyone know where I can get this oring?
Old Dec 29, 2011 | 06:23 AM
marcusE's Avatar
Old Dec 29, 2011 | 08:15 AM
TheBoz's Avatar
stealership, or contact Shep, Jacks, TRE, Buschur, MAP, ect. Anyone of the listed places should be able to source that part for you. I would start at the dealership if you have one close.
Old Dec 29, 2011 | 04:11 PM
marcusE's Avatar
Dealer ship said NO GO. Shep trans has my tcase right now.. Will call tomorrow.
Old Dec 29, 2011 | 08:34 PM
marcusE's Avatar
bump... still looking. picture added as well.
Old Dec 29, 2011 | 09:14 PM
tscompusa's Avatar
did you really unbolt the back part of the transfercase to remove the driveshaft? dont you know it slides out? you didn't have to unbolt anything on the transfercase.
i can see everything Mitsubishi sees because i have the Mitsubishi parts applications they use.. i need more info before i can help you though.
if it really is where you circled in that picture then chances are there are no gaskets.
Old Dec 30, 2011 | 10:20 AM
marcusE's Avatar
Yeah.. I made a dumb mistake. I was following a DIY when I took out the Tcase and we ended up removing that.. Once It was off I was like wow.. That didn't need to come off..
The o ring that is in there is cut..
Tom I'll take pictures in a few minutes of the actual oring.
here it is :
Old Dec 30, 2011 | 05:50 PM
marcusE's Avatar
... I need to figure something out.. Putting the car back together tomorrow and would rather not use this O ring.. unless I can bond it or something.. When it came out it was like this ... and didn't leak.. Might be okay.
Old Dec 30, 2011 | 09:32 PM
marcusE's Avatar
tt
Old Dec 31, 2011 | 03:18 PM
tscompusa's Avatar
there is no part # for that piece. use ultra gray rtv. just make sure you let it sit a bit so it doesn't move as you put it back together. also even torque across the bolts so it smashes evenly. re-align it on the piece where you see its outlines from when it was previously pressed against it. id rtv the entire oring gasket thing and let it cure so it stays in place then torque down to spec.
either rtv or grease so it sticks in place.. up to you.
Old Dec 31, 2011 | 06:15 PM
marcusE's Avatar
Exactly what I did Tom, thank you for the input man I appreciate it.
I love the evo community definitely the best support thus far.
Car is running strong with new engine mounts, a built t case with LSD and a fresh new wheels setup..
Let me know when we can adjust my tune okay Tom?
and paypal still lol
Old Dec 31, 2011 | 06:47 PM
milford's Avatar
good luck on the fix...still laughing at you for doing this. RTV should do the trick though.
xXANCHORMONXx
Apr 5, 2024 01:01 PM
m4tt VIII
Mar 12, 2014 07:01 PM
RAYS WHEELS
Dec 26, 2013 03:52 PM
EVOMIZ
43
Nov 18, 2013 10:26 PM
marcusE
For Sale - Wheels / Tires
17
Dec 19, 2011 05:05 AM
