Kill 2 birds with one stone
Old Jan 2, 2012 | 08:05 PM
Shaneal's Avatar
Transfer case really? Anything we can do to support it?
Old Jan 2, 2012 | 11:28 PM
sktng22's Avatar
http://www.sheptrans.com/transcase/evo.htm
Old Jan 2, 2012 | 11:57 PM
WickedIXMR's Avatar
Originally Posted by sktng22
the transmission is fine. its the transfer case thats the weakest part. that and rear diff take a beating
More dumb advice coming from you...
The transfer case is not the weakest part. He actually has a VERY strong transfer case since he has a IX. Its the 2003 VIII's that has issues with the spider gears. LOL! Rear diff?! Are you stupid? The rear diff is the last thing that fails on these cars. You should know what you're talking about before giving out advice that you have no idea of.
To the OP'er, I wouldn't worry about your T-Case unless you drag race your car every other weekend. Then I would do the SIMPLE Shep rebuild just for extra insurance. Since you have a IX, you already have the LSD that holds up just fine.
The transmission however, I would definitely rebuild while its out. There's a lot of revisions that need to be done that Shep takes care of to prevent certain problems to surface. The roll pin coming off for one which will leave you without certain gears and you'd have to take the trans back off to fix.
If you're coming up on 60k miles why wouldn't you replace the OEM TOB? You'd be stupid not to. Its a bearing, they wear out.. If you only had about 20k miles, then yes I'd say you could reuse it.
Old Jan 3, 2012 | 12:40 AM
sktng22's Avatar
more advice coming from someone who couldnt even build there own motor... think whatever you want kid. i think you should go talk your trash on another forum like vwvortex youll fit in there with how all you do is insult people and think your god.
Old Jan 3, 2012 | 12:43 AM
sktng22's Avatar
delete
Old Jan 3, 2012 | 07:16 AM
Broham's Avatar
6speed or 5?
Old Jan 3, 2012 | 04:45 PM
Shaneal's Avatar
6.
Old Jan 3, 2012 | 04:46 PM
Shaneal's Avatar
How much is a tranny rebuild?
Old Jan 3, 2012 | 05:50 PM
Broham's Avatar
if you have the 6, just get the kit from shep to do the swap. round 500 bucks and then get a 5speed transmission from shep/buschur or tre. THey all do good work. The 6 speed can't handle high wtq. DO the clutch and trans, but don't waste money rebuilding 6speed, swap to a 5
Old Jan 3, 2012 | 06:31 PM
Shaneal's Avatar
How much torque can it handle?
Old Jan 3, 2012 | 06:36 PM
deylag's Avatar
If I am not mistaken the six-speed is only rated to 290 ft-lbs.
Old Jan 3, 2012 | 07:33 PM
Raptord's Avatar
Depends what you do with the car. Road racing and lots of high-rpm driving will cause it to heat up quite a bit more than usual, which is the real problem with the 6-speed. Supposing you don't beat on the tranny and shift it nice and smooth I believe it usually holds up just fine up to around 350 wtq.
Old Jan 3, 2012 | 09:34 PM
Shaneal's Avatar
Wow just 350? Well that sucks. Thanks though. Adding that to my list of to-dos before power
Old Jan 4, 2012 | 05:38 AM
Raptord's Avatar
As always, your mileage will vary. Just because I said that doesn't mean it'll blow up the second you dyno 351 wtq.
Old Jan 4, 2012 | 06:30 AM
Broham's Avatar
I have 387 wtq on 6speed, but either way, going to a 5 is best. Id say enjoy your car at 350wtq and when you want more wtq, fully build the car. Its the only way to have a reliable high torque car. I'm losing tons of tq because I'm trying not to blow my motor/trans, but once swapped I can crank it up and damage all the passengers necks
ilovebowbies
Apr 20, 2016 09:37 AM
krazybai
Nov 18, 2015 12:14 PM
ohmohm
Sep 30, 2015 08:23 PM
MarksIX
Southeast Region
Jan 14, 2011 02:10 PM
evoIX15
Apr 16, 2010 10:03 PM
