shell rotella t6 5w-40
Old Jan 3, 2012 | 08:10 AM
vinNybXx's Avatar
Im sorry I dont mean to make another oil thread or debate, but I was just curious about this oil. I hear alot of good things about in a quick google search, i was wondering if any evo owners are using this oil? and how they like it? I did searched and couldnt find much, im thinking of making the switch and just wanted to see what you guys though. btw is this a good oil to run in nyc winters?
Old Jan 3, 2012 | 08:17 AM
nollij's Avatar
It is a great oil. They sell it at Walmart so you can get it cheap. Lots of people with turbo cars run it.
The oil sample results look compareable to the oils FP recommends for their turbos.
The 5W40 makes cold starting easier on the engine but considering you are not going to reach the higher operating temperatures for the 40 weight, you may want to use another oil for the winter or bypass your oil cooler.
Old Jan 3, 2012 | 08:20 AM
cmspaz's Avatar
If you're not reaching normal 40 weight operating temps in the winter you're not having enough fun.
Old Jan 3, 2012 | 08:22 AM
vinNybXx's Avatar
thanks for the quick reply I heard this oil is good for the winter, basically a all year round oil?. And its great this oil is cheap, available to pick up at a local auto supply store and proven!
btw i have a 35r on a stock block making around 460whp
Old Jan 3, 2012 | 08:42 AM
apagan01's Avatar
NY NY , deserves a 5W30 when its cold, unless you are running the car all out.
Old Jan 3, 2012 | 11:26 AM
nollij's Avatar
This would probably work better for the winter.
Ideally, you keep an eye on your oil temps and pick your oil accordingly for your driving situation.
However, 5W40 should be fine on the engine/turbo in the cold months and I would definitely recommend not running anything heavier (ie: 20W50).
Old Jan 3, 2012 | 05:10 PM
vinNybXx's Avatar
thnx for the advice..anyone else have experience with this oil?
Old Jan 3, 2012 | 05:16 PM
Anonymouse's Avatar
So has anyone on here ever done that oil lab analysis on this oil yet? If so can you post it up?
Old Jan 3, 2012 | 05:22 PM
TurboTravis's Avatar
Fantastic oil choice.
Explain. I'll wait.
Old Jan 3, 2012 | 05:36 PM
prowakeskater's Avatar
interesting...
Old Jan 3, 2012 | 05:52 PM
Steven's Avatar
I've been using it in my cars and bikes for the last 5 years. The new T6 formula has a little less ZDDP than the old version from a few years ago, but I haven't seen had any issues. I just pulled my 57K mile engine apart and everything looked great, but in all fairness, it's only been running Rotella for 5K miles. My GSC S2 cams and FP Red turbo appear visually as good as new.
Old Jan 3, 2012 | 06:29 PM
vinNybXx's Avatar
I seen on analysis and the results were very good, let me see if i could find it again now
Old Jan 3, 2012 | 07:21 PM
its wet-clutch safe? no friction modifiers?
Old Jan 3, 2012 | 07:32 PM
Steven's Avatar
http://en.wikipedia.org/wiki/Shell_Rotella_T
Works great in bikes! I would change the oil every 4 track days or 2K miles on the street, and never experienced clutch slip on any of my bikes. (2004 ZX-10R, 2006 R1, 2001 929, 2001 R6)
I've never had oil related issues in any of the vehicles I've owned. (3 Evos, numerous DSMS, Audi A4 1.8T, and many more!)
Old Jan 3, 2012 | 07:34 PM
nice. looks like ill be switching!
