Cheap way of compressing valves to get keepers out!
Old Jan 11, 2012 | 10:20 AM
My03evo's Avatar
Arrow Cheap way of compressing valves to get keepers out!
While I got my head off I want to take out my valves for inspection and a lap job or more. Is there any ways to compress the spring to get the keepers out? I have a modified c-clamp to work on my mustang and normal NON-OHC motors but won't work on this (not easily) because how deep it is in the head. I don't have a drill press either like how some shops do it. Is there a homemade tool that can be made to do this? Snap-on has a tool that bolts to the cam caps or somewhere and theres a pivot point and you just put the thing on the retainer and push it down but I'm not going to pay that much for a tool I'll rarely use. I'm sure some have done it Any home-made tools to do this?
Old Jan 11, 2012 | 10:23 AM
StreetThisEvo's Avatar
In the past I have used a deep socket (maybe 16mm or so) and put it on top of the retainer and hit the socket with a mallet or big hammer. That will knock the keepers loose.
Old Jan 11, 2012 | 10:53 AM
Arxylis's Avatar
^ This... Works great and is way quicker than using a spring compressor. Just make sure you don't do what I did and lose any keepers in the process...
Old Jan 11, 2012 | 11:04 AM
tsidrift1's Avatar
It works great for popping them out, but getting them back on is another story lol.
Hopefully I can type this so someone understands it lol.
I use the socket method to pop them out, always works, just be careful not to lose some keepers lol.
For putting them back in(with the head off the car) I use a huge c clamp, large enough to have one end on the retainer, and the other on the bottom of the valve. Then I use a plug cutter for a drill.
http://www.google.com/imgres?q=plug+...1t:429,r:3,s:0
This is almost like a socket, kinda. Except its just round on the bottom and has a good portion of the side cutout of it. This normally fits into a drill, well, I put it in a 3/8 drive 1/4"socket. This gives the top of the c clamp something to sit on. Then I carefully tighten the c clamp down, with the bottom of the plug cutter on the retainer, until I can get the keepers in. Having the plug cutter, with its side cutout, allows me to sneak in there with a small pair of needle nose and put the keepers back in. Once they are in, I carefully back off the c clamp and, done! Move onto the next.
It def helps with a buddy holding things while I tighten the c clamp though.
Old Jan 11, 2012 | 11:21 AM
mt057's Avatar
They make a valve spring compressing tool so that you can change springs with the head on. I think it would make it easy. I will see if I can find a link.
Old Jan 11, 2012 | 11:32 AM
Spec-Ops1's Avatar
http://www.euroexportinc.com/store/m...ompressor.html
Old Jan 11, 2012 | 12:38 PM
Aby@MIL.SPEC's Avatar
if you mess up a valve, it's going to cost way more to fix your problem then it will for a tool you only use once.
the link above looks like a no hassle set-up & is even cheaper than a snap-on kit....
iirc, the snap-on universal kit is ~$90 or so.....thats what i paid for mine ~7 years ago.
Old Jan 11, 2012 | 02:19 PM
tsidrift1's Avatar
That tool in the link looks like a sweet gadget. Ive never seen that before lol.
Old Jan 11, 2012 | 05:34 PM
Spec-Ops1's Avatar
The kit above makes it pretty easy to do springs/retainers in car!
Old Jan 11, 2012 | 05:46 PM
WHTEVO's Avatar
I've had the best of luck with the snap-on tool. Tried the c-clamp types and they suck IMO.
Aaron
Old Jan 11, 2012 | 07:51 PM
TommiM's Avatar
Originally Posted by Freddie@Spec-Ops
thats a sweet tool. On a 3sgte I did recently Toyotool makes a little device that you push down on the spring/retainer and it picks up the keepers so they dont get dropped. You then flip the adapter to reinstall. That was a really nice tool as well. With that tool in your link how would you keep the valve from dropping down though?
Old Jan 12, 2012 | 06:01 AM
Spec-Ops1's Avatar
Compressed air into that cylinder...
Old Jan 12, 2012 | 06:16 AM
WHTEVO's Avatar
Or the rope "trick".
Aaron
marksae
91
Apr 23, 2018 07:48 AM
Sheasta
Feb 9, 2014 11:13 AM
2006GSR
Apr 10, 2013 12:59 PM
dr_latino999
Oct 5, 2012 10:56 PM
metalmellinium
Northwest Region
Apr 20, 2008 09:52 AM
