How to get such exhaust sound?
Old Jan 15, 2012 | 08:54 AM
twabtoxer's Avatar
just take the exhaust off. just use the downpipe. you will get all sorts of growling noises
Old Jan 15, 2012 | 10:00 AM
jameswwt's Avatar
Originally Posted by Mellon Racing
that sounds like a straight pipe almost. I have the buschur 3" turbo back, test pipe and ultra free flowing bullet muffer. It's loud but it doesn't have the turbo whistle at idle. http://www.youtube.com/watch?v=Zk-a6...2&feature=plcp
Dam...why cant my Gsc S2 cams gave me such high cam sound???
Old Jan 15, 2012 | 10:21 AM
Babs's Avatar
Originally Posted by badev0
The red EVO VI's exhaust in the video is exiting out the front bumper. That's why it is so loud and you can hear the turbo at idle.
This.
Go look at any stripped drag Evo with an exit out the front end and it'll have this same sound. It's not titanium or anything fancy involving free flowing exhaust. It's because the exhaust is literally 1 or 2 feet long.
Old Jan 15, 2012 | 10:26 AM
Babs's Avatar
Here's essentially the same thing...only thing different is that you're not hacking your bumper up.
http://www.youtube.com/watch?v=jr2zKLxia3E
Old Jan 15, 2012 | 12:46 PM
Mellon Racing's Avatar
I'm running the BF272 cams which are a bit more aggressive. The idle rpm has something to do with it as well.
Old Jan 15, 2012 | 05:57 PM
jameswwt's Avatar
Hi Mellon Racing,
mind to share what's yr idling rpm? Mine is 1,100rmp w/o aic-con & 1,000rpm w/air-con on...Can i set the AFR leaner a bit more on idling to get such cams sound?
Old Jan 15, 2012 | 06:36 PM
it was idling at 1100 in that video if I remember correctly. I've never attempted to change the idle lope with AFR changes.
Old Jan 15, 2012 | 07:57 PM
jameswwt's Avatar
Thanks again Mellon Racing...
Old Jan 15, 2012 | 08:01 PM
Macaroni's Avatar
I have a 84mm fpred and the AMS 3" turndown and I definitely have the turbo whistle your speaking of. Since the 3076 and the fpred are essentially the same turbo you should have similar effects. I can post a video if you like
