Why I will never go back to a 2.0L
Old Feb 2, 2014 | 05:21 PM
  #151
420a-t's Avatar
Im building a 2.2l utilizing a 94mm crank, 2.1l pistons, 150mm rods and a 63 block which I think puts the rod ratio and piston speed between a 2.0l and a 2.3l
Old Feb 3, 2014 | 07:43 AM
  #152
mitsubeastlee's Avatar
Originally Posted by rick1024
i cant answer that from experience, but if i were gonna go through the trouble of using a 2.4, why not get the full effect and utilize all 2.4 liters?
Typically because 2.4l motors can't rev and stay together at 9k plus when drag racing. Most builders don't prefer using the 4g64 block because of less cylinder wall meat but some say it's still plenty.
Old Feb 3, 2014 | 12:06 PM
  #153
JohnBradley's Avatar
Originally Posted by fafaforza
OK, so for the uninitiated, are you guys talking about boring out the Evo 8/9 motor? Or dropping in a larger engine from another Mitsubishi car?
The 4G64 from the Eclipse/Outlander/Galant
Old Feb 3, 2014 | 02:59 PM
  #154
rick1024's Avatar
well, if i ever go into another build, i think this time i will go with a 2.3 4g63. the 4g64 has a lot of power but i dont like how alien it seems to be.
Old Feb 10, 2014 | 06:50 PM
  #155
Alien? Dont quite follow. Its been being put in DSMs with the 16V head since 98, its pretty known tech. Heck it was factory in 99 in the Spyder (non turbo though).
Old Feb 11, 2014 | 02:40 PM
  #156
Besides running a waterpump spacer and having weird timing gear marks I don't know of too much more differences over the standard 4g63 in terms of install
Old Feb 11, 2014 | 02:44 PM
  #157
d-bo's Avatar
I believe you just use an oem mistu pump from a certain year outlander and it requires no spacer
Old Feb 11, 2014 | 03:27 PM
  #158
rick1024's Avatar
isnt there some kind of fix needed to run mivec on one? i remember reading on the original owners reciept for this build that there was a charge on it for the mivec feed fix or something
Old Feb 11, 2014 | 04:01 PM
  #159
galantman03's Avatar
yes the 4g64 requires tapping for the mivec line
I originally had the 4g64 in my galant, so when I built the motor, I have the same displacement that came with car from factory, actually its the factory block for mine. 2.4LR with an evo 8 head. If you get nice cam gears, timing isn't that far off. And if you degree your cams like your supposed to, its not the complicated at all. yes the outlander water pump will work. did I use it? no, i used the spacer.
Old Feb 15, 2014 | 03:40 PM
  #160
Talonboost's Avatar
Does this include the current production Outlander? I see that the standard engine in most 2014 Outlanders is a 2.4 liter, but MSN Auto lists the stroke of this engine at 3.82 inches, which is 97 mm. Is this a 4G64?
Old Feb 17, 2014 | 12:14 AM
  #161
rjgrant's Avatar
This makes me think of going 2.4.. was thinking of 2.2, but having second thoughts..Nice numbers man
Old Mar 2, 2014 | 07:54 PM
  #162
Oxford's Avatar
Nice numbers!
Old Oct 17, 2024 | 11:55 AM
  #163
gspec76's Avatar
I think we have and it is only going to grow I feel.
...also I realised I forgot to post my before and after results-
This is 23psi though not marked on the 499 run.
Speaks for itself I think, 300 ft lbs of torque at 4400 or 5100? Hmmm hard choice
I have been wanting to contact you about having an engine built but I am limited to forum actions as I am a new forum member😔
Old Oct 17, 2024 | 02:02 PM
  #164
LetsGetThisDone's Avatar
Just call English Racing.
Old Oct 17, 2024 | 02:08 PM
  #165
Talonboost's Avatar
Yeah call English Racing. Or email them.
"JohnBradley" is Aaron at English Racing.
If you call, it will probably be Myles who will answer.
Myles is this guy:
