Why I will never go back to a 2.0L
Old Feb 24, 2012 | 08:02 AM
  #106
JohnBradley's Avatar
Originally Posted by pure_evo
OK. I just need to make sure that I am following you correctly. Are you saying that with a nice head, you were able to extend the powerband 600 RPM?
Yeah the 600rpm is the inherent difference between a 2.0L and a 2.4L. Its not to say that a good head and cams wont do the same but I havent ever gotten over 7800 in the 2.4 for peak power.
Aaron
Old Feb 24, 2012 | 08:24 AM
  #107
Levar's Avatar
Veteran: Army
Originally Posted by bbyevo8u
lol no he's simply giving the difference in when the two motors start to gas out and there is a 600rpm difference between the 2.0 and 2.4
OK. Thanks. Awesome.
Old Feb 24, 2012 | 11:30 AM
  #108
DJAfterShok's Avatar
I can't wait to start my 2.4LR! I hope i get some decent results with a FF BB Black!!!
Old Feb 24, 2012 | 07:09 PM
  #109
batty200's Avatar
I have decided to do a 2.4L on my EVO and keep my original shortblock off to the side incase I blow the built motor. Cant wait to see how it does. Still deciding between a long rod and a std rod 2.4. I need to learn more about longetivity effects of shorter piston skirts before I decide. I also want the lowest expansion pistons so I can do a tight tolerance build. I hate blowby and piston slap.
Old Feb 24, 2012 | 10:56 PM
  #110
Acree's Avatar
Even if you blow it... you're better off selling your shortblock right now, and buying another 2.4L when it goes. Intact 4G63's go for a premium. I would put the money back into the car.
-Acree
Old Feb 24, 2012 | 11:44 PM
  #111
Levar's Avatar
Veteran: Army
Has someone come up with that "2.4LR Army" sticker yet? I purchased my 2.4LR last week.
Old Feb 25, 2012 | 06:55 PM
  #112
batty200's Avatar
-Acree
I agree but owning the original motor that the vin #'s match the car is something worth something to me. I will prob end up selling it though because I am poor but I would RATHER not.
Old Mar 19, 2012 | 06:15 AM
  #113
boostedup's Avatar
hey maybe i was just being blind but i did not see any dyno sheets showing a direct comparrison between the 2.2 and the 2.4 i would be interested to see if any one has this info
Old Mar 19, 2012 | 06:37 AM
  #114
Sharkbite2000's Avatar
I see that it will not give your the rev's of a 2.0L. I had trouble with my 2.3 not getting the MPH I wanted and had to get the 4.11 gear to open her up.
Old Mar 19, 2012 | 10:34 AM
  #115
I dont have a back to back between mine, I changed cams between the 2.2 and 2.4 though I suppose it would show spool difference.
Old Mar 19, 2012 | 10:36 AM
  #116
This will be the best option with any long stroke motor. The LR2.4 I have only taken to 8900 so far. The motor that is in the car this year will be more akin to a long rod version of Dave's 2.3RPM. I still dont plan on revving it over 9300 though. With the auto having 4.13 gears it wont be needed anyway...or shouldnt if things go according to plan.
Old Mar 20, 2012 | 04:11 PM
  #117
Graphic's Avatar
Aaron, if you were to raise the boost on the 2.0L to reach the same power, do you think your numbers would be comparable? I know it's more abuse to get there, just curious..
Old Mar 20, 2012 | 06:43 PM
  #118
https://www.evolutionm.net/forums/9970933-post98.html
Old May 26, 2012 | 09:37 AM
  #119
keath's Avatar
anyone have experience with 2.4 LR with small turbos? (stock, bbk full, HTA71 etc...)
I am getting the ER 2.4 LR as we speak,(BTW ER's customer service is beyond awesome) but i dont think my turbo (HKS 7460) will even hit 450hp because it is so small.
I love the quick spool of HKS even on 2.0 and hoping it will spool faster with 2.4.
I would just want some feedback from guys who have 2.4 with small turbos.
Another Q is with Aarons magical tuning skills it could hit 460\460 on ER's Dyno?
That is my goal because this is my DD with little bit of PIR track days.
thanks guys
Old May 26, 2012 | 05:07 PM
  #120
AreSTG's Avatar
kind of a tough call, since a lot of the turbo manufacturers don't post turbo maps to see where you engine is going to fall into teh efficiency range. I think there is a point where you're throwing so much at the small turbo it would be making more power even in the lower RPMs with a bigger turbo.
Unless you're strapped for cash, you could always just use the turbo you currently have which isn't going to cost anything extra. And if it isn't what you want, now you KNOW it's not what you want. otherwise you may always be wondering.
I had the same decision to make with a 2.4, i considered staying small. But i can only imagine overspinning a little BBK like crazy at 7.5k rpm on a 2.4L.
I say try it out, and worst case you decide to upgrade, and have no regrets. I'd be interested in seeing the results. This just a street car?
