FP71HTA vs BBK Full
Old Feb 1, 2012 | 07:41 AM
  #31
CBRD's Avatar
Originally Posted by 94AWDcoupe
71 hta is using the stock turbine wheel. you can only make so much power through a stock hotside. the 71 is virtually identical in potential to BBK lite. both turbos are pushing the limit of stock turbine wheel.
its a shame project bastard 550550BBK didnt bolt in other turbos like they planned. especially the HTAgreen. no one has ever done a back to back with those. project bastard had high compression. very important key to high HP small turbo setup. limited air flow should have small combustion chamber to fill to maximize the setup.
plus they swapped to a garrett core fmic when they changed turbos while ours had an ebay fmic during testing LOL!
I do agree with you though- with upgraded wheel on stock turbine- it makes for a massively quick spooling setup with good power potential, but as soon as you add the turbine upgrade you find that you are making same power- EASIER-
thanks for input-
cb
Old Feb 1, 2012 | 08:24 AM
  #32
Strictly Modified's Avatar
Ordering your parts as we speak Jason! I will call you shortly to schedule. We are stoked to see the end result.
-Cisco
Old Feb 1, 2012 | 08:46 AM
  #33
211Ratsbud's Avatar
I have a 71hta that I will submit for some back to back testing, and if somone will split dyno time I will drive my turbo to the dyno so we can make an excellent comparison. if somone with a BBK full in the NE PA, or downstate NY would play!
Thats my offer, this thread is great, a third party test comparison would be the icing on this already great discussion.
my.02
Old Feb 1, 2012 | 10:12 AM
  #34
asubennett's Avatar
-Cisco
Thanks man. Im stoked too. :-) my jdm rear should be here soon to and we can post a few pretty pictures with an even prettier dyno graph. Ill drop the rear off as soon as it arrives.
Old Feb 1, 2012 | 10:18 AM
  #35
Nice!! Looking forward to it.
-Cisco
Old May 29, 2013 | 10:24 AM
  #36
EvocentriK's Avatar
If when set up for road racing with a mind to keeping combustion chamber temps down by not choking the turbine up top, the BBK Full seems to be happy at 24 psi, with it starting to choke above that up top as seen with torque drop off and loads dropping.
At what point does the BBK Lite/HTA71 start to choke up top?
jnut24
Mar 8, 2017 02:42 PM
dookiedang
Sep 9, 2015 09:29 AM
IGGZ
Aug 10, 2015 04:24 PM
snafufx
42
Apr 16, 2012 06:56 PM
dmotors
May 9, 2011 10:38 AM
