Injector seals, on the cheap from O'reilly's Auto Parts
Old Feb 5, 2012 | 02:07 PM
Spec-Ops1's Avatar
I know everyone has been in a pinch and needed the big injector seal that goes into the intake mani... I needed some today and after doing a bit of research I ran across some at O'Reilly's auto parts. It is a seal kit for a 2000 Toyota Tacoma 2.4, Borg Warner Fuel Injector Seal Kit, Part Number: 274531. The kit is $3.99 per injector, however it was a tad cheaper with the ole military discount... Thought this might help if you can't wait on them from the dealer!
Old Feb 5, 2012 | 02:08 PM
Jtoys's Avatar
Thanks!
Old Feb 5, 2012 | 02:38 PM
Spec-Ops1's Avatar
No doubt
Old Feb 5, 2012 | 02:45 PM
B.J.@ToxicFab's Avatar
Good to know, thanks for sharing Freddie!
My03evo's Avatar
Guess none would come up if u looked it up under an evo?
Old Feb 5, 2012 | 04:34 PM
AreSTG's Avatar
good stuff as always Freddie, thanks
Old Feb 5, 2012 | 05:24 PM
Spec-Ops1's Avatar
Thanks guys!
No, just the o-rings for the top of the injectors
Old Feb 5, 2012 | 05:31 PM
Steven's Avatar
Or $4.59 from NAPA part number 2-12069.
Old Feb 25, 2012 | 05:54 PM
greencow's Avatar
Man, what timing. I'm planning on getting my car tuned next weekend, did another boost leak test just for sh*ts 'n' giggles, found out that one of my injectors is leaking upwards of 26psi.
I'll have to run up to oriellys and see if I can't get a few sets of these. Thanks man!
Old Feb 25, 2012 | 06:47 PM
cmspaz's Avatar
Nice! How'd you figure that one out?
If all the seals in the kit fit our injectors, let me know and I'll put through a catalog update for it.
Old Feb 26, 2012 | 07:29 AM
Spec-Ops1's Avatar
All of them do minus the big o-ring, which doesn't fit anything...
Old Jul 2, 2012 | 11:12 AM
Bumping the old thread.
Getting an E85 smell from near the injectors so I just picked up this kit 274531.
Curious why the above quote notes to use all the seals except the large one.
To me the 2nd & last from left are the only ones to use
EDIT: Freddie PM'd me. Got it figured out
Old Jul 4, 2012 | 11:19 AM
This kit did not work for me. Performed the install using the 3 seals (upper, lower & the seal below the uppers (channeled seal) Note: The channeled seal does not fit the RC injector. So I only used the upper seal
Cranked over the motor (did not start) & immediately had a small fountain of corn juice pissing all over.
Checked to find fuel leaking at the bottom seals.
Removed everything & measured the OEM bottom seal vs the BWD. Huge dimensional difference in O.D. & I.D.
Anyway, Used my original bottom seals & used the BWD upper seal.
P.S. The reason I changed my seals is that I had a small fuel leak somewhere at the injectors. See torn upper seal bottom left
IMO. This BWD kit is not right
Peace, Joe
Old Jul 4, 2012 | 12:14 PM
nightwalker's Avatar
Lube with vaseline and squeeze
Old Jul 4, 2012 | 01:57 PM
hiner005's Avatar
Military discount for the win. I love when people give me those...makes me sad when others dont!
