New or Used Spoolin' Up COP?
Old Feb 14, 2012 | 02:34 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
So, I'm going to pick one of these up, but before I drop $420 on a brand new unit I have to ask:
What's the benefit of new over used?
Discuss.
Old Feb 14, 2012 | 02:37 PM
snafufx's Avatar
I got a used one and it looked brand new to me,not one difference.
Old Feb 14, 2012 | 02:38 PM
SDevo13's Avatar
If cash is not tight I'd get new. If it is, get used.
Old Feb 14, 2012 | 02:40 PM
okevolutionVIII's Avatar
They just have used coils but my "Used" COP looked brand new.
Old Feb 14, 2012 | 03:18 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Why?
You've got to have a reason if you want to convince me.
I purchased my car used because you get ****ed on a new car. Most people want a new car because they think that a used car is 'tainted' or some ****.
Old Feb 14, 2012 | 03:23 PM
dtrackstar's Avatar
My used kit new. No issues.
dtrackstar's Avatar
Used kit looked* new
Old Feb 14, 2012 | 10:07 PM
evoballer's Avatar
1+ on the used kit! love min, looked and worked like brand new
Old Feb 14, 2012 | 10:14 PM
SDevo13's Avatar
Originally Posted by golgo13
Why?
Coils eventually wear out. Thus used will have a shorter lifespan, not that it will be an issue for most. So again, if you are in a squeeze for $$$ buy used, if you aren't get new coils *shrug*.
Old Feb 15, 2012 | 05:04 AM
Davo's Avatar
at one point Matt had said that used kits can't be hid whereas the new could be hid under the coil cover
not sure if he sourced used that can now hide
Old Feb 15, 2012 | 09:57 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I picked up a new kit.
I'd rather have one I don't have to worry about.
Old Feb 16, 2012 | 06:55 AM
boozeup&riot's Avatar
I believe that's been resolved, and even the used can go under the spark plug cover now.
Having said that, the benefits of going new vs used are universally applicable. Gently used can save you some $$. Brand new offers more peace of mind.
Old Feb 16, 2012 | 05:59 PM
TommiM's Avatar
I went used, and my used kit fit under the stock cover. Reason is, imo the slightly used will still be just fine. Coils will wear out over time, but even at 60k miles they should still fire within spec. Within spec should be enough to give you enough KV for your evos ignition. The Denso coils Spoolinup uses are really high quality, I have seen a used denso coil perform better than a new off brand coil.
Spoolinup tests each coil so you will have peace of mind that your getting a good coil. I am confident with used coils since I have personally seen quite a few 100K+ mile cars with the original denso coils still operating just great. If one of your used coils goes bad you can just purchase a new coil individually at that time anyhow. FWIW, a new coil can go bad just as easily as a used one.
RupertisRed
Jan 19, 2023 06:56 AM
katchup
Oct 2, 2011 06:47 PM
JDMonster
May 1, 2010 07:31 AM
stevoooo
Jan 11, 2010 07:59 PM
evov8
Jul 7, 2004 01:40 AM
