Timing with The blance shaft gear
Old Feb 15, 2012 | 09:30 AM
bubba17's Avatar
so i did some searching found nothing. the shop put the balance shaft eliminator in my car. however i did some research seems like graveyard dsm is saying if the balance shaft is eliminated the sprocket does not have to line up. which the shop did not line mine up but i see some people still do it for personal reasons. just want to double check before i bust thing thing out of the garage for hybernation and starts causing trouble and don't want that vibration in the wheel. is this a true statment? or is there downfalls in the long run.
Old Feb 15, 2012 | 09:59 AM
okevolutionVIII's Avatar
You won't have a problem, it can't cause vibrations as it's not spinning a shaft with counter weights anymore. If you still had the shafts in and the gear wasn't lined up, then you'd have problems, maybe the shaft hitting the crank.
Old Feb 15, 2012 | 10:31 AM
bubba17's Avatar
i know he modified my stock shaft and its a stub shaft pretty much
Old Feb 15, 2012 | 10:54 AM
The whole reason for having balance shafts is to reduce/cancel out vibrations but you'll be used to not having them pretty quick.
Old Feb 15, 2012 | 11:23 AM
bubba17's Avatar
good deal so im guessing i can leave it alone the way it is and not worry about retiming it
Old Feb 15, 2012 | 11:26 AM
Yep, the balance shaft timing gear is no longer a concern.
ReivaXVrai2
75
Jan 21, 2017 07:28 PM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
D-VO
20
Sep 30, 2010 09:24 PM
David Buschur
89
Aug 28, 2010 09:47 PM
SPOOLEDTSiAWD
75
Nov 25, 2007 09:09 AM
