22 psi evo 8 wastegate on a ix turbo?
Old Feb 16, 2012 | 07:05 AM
EriCS's Avatar
Whats up everybody, I think my stock ix wastegate is having issues. I was wondering if a 22psi evo 8 wastegate is a good idea to install. I am running about 23psi of boost. Will this effect my tune?
Old Feb 16, 2012 | 09:34 AM
MechTech's Avatar
Don't bother, just buy a boost controller and install it.
Edit: Yes it can affect your tune.
Old Feb 16, 2012 | 02:37 PM
sparky's Avatar
Do you have the VIII WGA already? Normally, the IX actuators won't fit the VIII turbos and vice versa. At your peak boost level probably the FP HD 18 PSI IX actuator is the way that I would go.
Before you go and spend money though I would try adjusting the spring tension on your stock IX actuator. It should work fine in the low 20's range that you have peak boost set at.
Old Feb 17, 2012 | 08:05 AM
EriCS's Avatar
Shortened my stock ix wastegate actuator rod and walla its fixed. Be sure for those of you who do this to turn your crack pressure down to compensate for the new preload.
nd_danial
Jun 15, 2017 12:44 AM
studioface
Aug 18, 2016 09:14 PM
Javo_EVOVIII
Aug 9, 2010 01:21 AM
eb66
Apr 28, 2010 07:01 AM
~EVILEVO~
Sep 28, 2006 05:42 PM
